-- Time For New Tires --- You Choose!
Out of these (205/50/17), under $100.
Which one would be best for FE? Compare Tire Search Results YOU CHOOSE! I AM BUYING THEM TOMORROW OR SUNDAY, SO DECIDE! I was thinking the Goodyear RS-A; they come oem on Honda civics, and some say they last about 70k miles so they must be pretty hard even though the rating is only 280 ... ? |
Scratch all of the Snow Tires. Maybe the All Season too. Summer tires will have the best tread wear and presumably better RR.
Reviews say they have lasted over 50k for some people, and they are harder at 420 AA A |
Lasting longer and being harder has nothing to do with rolling resistance. Many LRR tires are soft and some have low wear ratings. Silica blends seem popular for LRR.
Hey quick question...
I gave yall all 215/50/17's.. do you think it will be fine to run 205/45/17's? They are 2lbs lighter, and $20 cheaper... ? I know the speedo will be off 4% but should I do it or just stick with the 50 sidewall? PLEASE PLEASE HELP IM BUYING TODAY...! |
alot of choicess under a 205 /50 r 17
i would stick to those |
Hopefully, you did not buy the 45 series tires. They are lower in load carrying capacity and that increases the risk of a load related tire failure, which sometimes has tragic consequences. |
Well I ended up getting the Kumho Ecsta ASX in 205/50/17.
They seem to last to over 50k regularly, weigh 22 lbs, have a 420 AA A rating, and can be inflated to 51psi :D So they are a bit skinnier than my current tires (the ones that came with the car), those were 215's... and those could only be inflated to 42psi; so we will see what the gains are hopefully 1-2mpg's can be possible. |
Watch these tires very carefully for signs of bulges. You live in one of those areas that have been identified as problem areas for tire durability! |
Yes no I will definitely keep an eye out, even though I have removed about 80lbs of weight from my car so that should help a tad bit.
What I thought about was that my car (4cyl) and the 6cyl model have the same tires, and of course they have to put tires that fit the 6cyl weight- in other words, its probably a bit much for the less weight 4cyl model... get me? Also, I looked at the 215 tires that I have right now and actually they have the same exact max load rating on them as these 205's (probably because the 205's have a higher UTQG rating thus a harder sidewall most likely). |
Hi,
What is the maximum weight they are rated for at the max pressure? I'll bet that each tire can carry at least 50% more weight that you could possibly need it to... |
The 50 series that I got are at 1433, the 45 series were something like 12xx ... my car weighs around 3000lbs
And, no, it has nothing to do with the UTQG rating. |
Since I am on the subject...
Anyone changed to a tire 10mm or more narrower and have mpg data? |
Narrower will be better for FE, but you'll loose a bit of traction.
I'm also looking for tires for the Matrix come summer time. I've been looking at the Pirelli P6 Four Seasons. Quote:
Yea I saw those as well but the reviews weren't as good... plus they don't seem to last as long.
AND FOR ME... poor college student... I needed one set of tires that would last me all 4 years of college and I think these Kumhos are just the ticket :D |
IMO you can't trust those reviews much. The majority of people out there are probably running around with 20 psi in their tires and don't know that they're doing major damage to them. I also run a dedicated snow tire, so I ignored the snow traction. Also, if you read the reviews with more miles on them, and the ones that aren't aggressive drivers, those people loved the tire.
In any case, I'm sure most of the tires out there roll great when they have 50 psi in them. I try not to get too hung up on LRR, but you do wanna buy the best when you have the chance! :) |
Even if you keep the tire brand and tire line, the rim diameter, and the aspect ratio the same, the load carrying capacity also changes. Since load carrying capacity seems to be a major factor in rolling resistance, only the width change should result in a slight increase in RR - worse mpg! But this change is so small that it is doubtful you can actually detect the difference in a vehicle. In your case, it looks like you have only kept the rim diameter and the aspect ratio the same. In other words, you've also changed tires as well as used a narrower width - and this complicates the issue too much to make a prediction. But you should be aware that - everything else being equal - new tires are always going to hurt FE compared to worn out tires. |
