Old 02-13-2009, 09:18 PM   #1 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
Question -- Time For New Tires --- You Choose!
Out of these (205/50/17), under $100.
Which one would be best for FE?
Compare Tire Search Results
YOU CHOOSE! I AM BUYING THEM TOMORROW OR SUNDAY, SO DECIDE!
I was thinking the Goodyear RS-A; they come oem on Honda civics, and some say they last about 70k miles so they must be pretty hard even though the rating is only 280 ... ?
Old 02-13-2009, 09:26 PM   #2 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Scratch all of the Snow Tires. Maybe the All Season too. Summer tires will have the best tread wear and presumably better RR.
Old 02-13-2009, 09:39 PM   #3 (permalink)
Sooo... Kumho Ecsta ASX?
Reviews say they have lasted over 50k for some people, and they are harder at 420 AA A
Old 02-14-2009, 12:52 AM   #4 (permalink)
93 Metro Streamliner
AeroMetro - '93 Geo Metro
Lasting longer and being harder has nothing to do with rolling resistance. Many LRR tires are soft and some have low wear ratings. Silica blends seem popular for LRR.
Old 02-14-2009, 01:51 PM   #5 (permalink)
Hey quick question...
I gave yall all 215/50/17's.. do you think it will be fine to run 205/45/17's?
They are 2lbs lighter, and $20 cheaper... ? I know the speedo will be off 4% but should I do it or just stick with the 50 sidewall?
PLEASE PLEASE HELP IM BUYING TODAY...!
Old 02-14-2009, 02:10 PM   #6 (permalink)
Johnny 5 - '81 Honda Cm400e
90 day: 42.86 mpg (US)
Da bike - '06 Honda Shadow Vlx deluxe
90 day: 59.47 mpg (US)
alot of choicess under a 205 /50 r 17
i would stick to those
Old 02-15-2009, 08:40 AM   #7 (permalink)
Tire Geek
CapriRacer's Avatar
Hopefully, you did not buy the 45 series tires. They are lower in load carrying capacity and that increases the risk of a load related tire failure, which sometimes has tragic consequences.
Old 02-15-2009, 01:06 PM   #8 (permalink)
Well I ended up getting the Kumho Ecsta ASX in 205/50/17.
They seem to last to over 50k regularly, weigh 22 lbs, have a 420 AA A rating, and can be inflated to 51psi
So they are a bit skinnier than my current tires (the ones that came with the car), those were 215's... and those could only be inflated to 42psi; so we will see what the gains are hopefully 1-2mpg's can be possible.
Old 02-15-2009, 02:55 PM   #9 (permalink)
Tire Geek
CapriRacer's Avatar
Well, what I said about the 205/45R17's applies to the 205/50R17's, just less so. They are smaller in load carrying capacity than your original tires - even considering the additonal inflation pressure you will be using.
Watch these tires very carefully for signs of bulges. You live in one of those areas that have been identified as problem areas for tire durability!
Old 02-15-2009, 05:32 PM   #10 (permalink)
Yes no I will definitely keep an eye out, even though I have removed about 80lbs of weight from my car so that should help a tad bit.
What I thought about was that my car (4cyl) and the 6cyl model have the same tires, and of course they have to put tires that fit the 6cyl weight- in other words, its probably a bit much for the less weight 4cyl model... get me?
Also, I looked at the 215 tires that I have right now and actually they have the same exact max load rating on them as these 205's (probably because the 205's have a higher UTQG rating thus a harder sidewall most likely).
Top 5 most fuel efficient tires (Lowest Rolling resistance: LRR) blackjackel General Efficiency Discussion 144 01-26-2016 12:39 AM
Tire Engineer here - concerned about hyperinflating tires CapriRacer Introductions 48 09-26-2009 10:25 PM
New Wheels & Tires trikkonceptz Success Stories 9 11-03-2008 03:05 PM
Crapped. 2 tires have bubbles. XyKo EcoModding Central 37 09-04-2008 05:55 PM
New tires, advise? Chris D. EcoModding Central 35 06-09-2008 10:53 AM
