"Tiny" Side View Mirror
Side view mirrors add to frontal area and create a lot of turblance which is not good for the aerodynamics of a vehicle.
A total mirror delete with the addition of a camera to take it's place would be ideal. However, besides the high cost, you are not allowed by the law to replace your mirrors with cameras (yet). Moving a mirror to the interior of a vehicle along with the view that is provided is inferior compared to a outside mirror. So, what can one do...??? Answer. Replace a existing mirror with this... http://i536.photobucket.com/albums/f...69/mirror1.jpg It is a mirror for a bicycle bought at Walmart for $6.99 . The mirror transplant patient. http://i536.photobucket.com/albums/ff325/dmt6969/0.jpg The original mirror. http://i536.photobucket.com/albums/f...69/mirror3.jpg Old mirror removed and hole drilled for the new mirror. http://i536.photobucket.com/albums/f...69/mirror4.jpg Picture of the new mirror disassembled. http://i536.photobucket.com/albums/f...69/mirror2.jpg New mirror installed. http://i536.photobucket.com/albums/f...69/mirror6.jpg http://i536.photobucket.com/albums/f...69/mirror7.jpg http://i536.photobucket.com/albums/f...69/mirror8.jpg Comparing the original to the new mirror. http://i536.photobucket.com/albums/f...69/mirror3.jpg http://i536.photobucket.com/albums/f...69/mirror7.jpg New mirror is approximately 3sq.inches. Old mirror is 10-15x that total. (size of mirror and mounting) Since the new mirror is adjustable in 3 axis, it was easy to mount to the face of the door and still have a level point of view. One could mount this mirror to a variety of vehicles with ease. So... Whats it like...??? Well, I took it for a spin and was pleased with the result...:) The field of view is pretty good. Also, it is quieter than the original. It is however like most other auto mirrors as the vehicles viewed are closer than they appear. Just so you know, the mirror is made of plastic and will probably scratch easily so it would have be treated carefully. Anyway, I hope this novel approach to a problem all our vehicles suffer from can help someone else. Have a Great Day... Redneck > |
:thumbup: Did you fill in the old opening with plastic? Closeup pic of the new mirror from the side, please. :D
redneck -
Great job! I used to have a tiny bicycle one (bottom mirror) : http://ecomodder.com/forum/member-cf...-1100-1986.jpg It would shake a lot because the arm wasn't designed for car speeds. When I was commuting I switched to a motorcycle mirror for the sake of my passenger's nerves and kept it. Soooooo, I chose the middle way. CarloSW2 |
I've always thought sports motorcycles mirrors are the most effective options, not compromising too much the visibility while retaining a good aerodynamic.
Do we have any A-B-A testing on a mod like this? I'm skeptical, although the surface area is smaller, the form of your replacement mirror is less aero than stock.
For example, look at these shapes: http://upload.wikimedia.org/wikipedi...4ilf1l.svg.png (Source: Wikipedia on Drag Coefficient.) I'm thinking half-sphere .42, vs short-cylinder 1.15. If the Cd difference were that large (it may not be), you'd have to cut the mirror area by almost 3X just to break even. The effectiveness of this mod might be 0. EDIT: Sorry, I was probably being a bit pessimistic. I have a bicycle mirror like that and I remember it being a bit curved on the back side. Also I reread and found where redneck said: Quote:
But I think my underlying point is valid; be careful selecting a smaller mirror, and A-B-A testing would be interesting. |
Why do you say it's less aero than stock?
I think your analysis is right. Maybe I should just say I was wrong. :o EDIT: you could also do the Bondo-on-foam method instead of modeling clay. |
http://i536.photobucket.com/albums/f...9/mirror13.jpg The Dime in the picture is for size reference. http://i536.photobucket.com/albums/f...9/mirror14.jpg Not the best looking, but good enough for now. > |
