Tire Suggestions...
I'm looking for "CHEAP" tires for my Commuter
I drive 120 miles/day, mostly 55/60mph 2 lane highways im in a 2001 Prius it's got 14" wheels currently sporting 175/65-14 these sizes fit easily on the stock wheels 185/60-14, 185/65-14, 195/60-14, 205/55-14 I've been told the car should have xl tires (xtra load) but it's only about 3K lbs what do you guys think? what about LRR (Low Rolling Resistance) tires? are they worth paying a bit more for? any suggestions? $41 each (stock size) Tire Details - Discount Tire $48 each (+size) Tire Details - Discount Tire $101 for the michelins Tire Details - Discount Tire |
Stock- unless you find something skinnier. Usually less RR, and more fun on the road.
Please note I haven't done any extensive research- if the stock tire is tirerack user review rated at 50k, while the $8 more tire usually goes 100k, then that's the way I would go. |
Try to find a balance between warranty lifespan, price, and RR. The cheapest tire might not be the cheapest at first. For example $41/tire for a 40,000 mile tire is more expensive than a $56/tire 80,000 mile tire in the long run. I always read through the reviews, it really helps to hear from actual owners of the tire, they will talk about road noise and any complaints they have.
As far as size goes I would stay at the stock size. You could increase diameter to lower RPM's on the highway, but the impact is minimal and usually bigger tires cost more. You don't want to go any wider as UltArc stated. |
Lots of 80+k tires will dry rot before you wear them out. Had that happen to my father in law when his Michelins were dry rotted with 90% of the tread left.
Most LRR tires a not super long lasting, they have less tread depth and weigh less. That can be more than offset by fuel savings. regards Mech |
If I wasn't going to get a lrr tire, I think I'd get the general altimax rt43, in the oe size
If all I wanted was mileage, despite seeming to be going backwards here, I might drop to the 165-65-14 lrr potenza re92. I have defenders myself |
I would normally say up size with as many mile as you drive.
lower rpms at cruise always helps mpg. But nut sure about a prius...... |
my commute is 60 miles each way, 5 days a week. (30,000 miles/year) |
not exactly sure how it would affect this particular car not a lot of people posting about the "Classic" (01-03) prius |
I have tires that are 1 inch increased diameter, it throws the speedo off about 5%. The effect is less than 300 RPM change, I figured it out before but forgot exactly how much. I don't really know much about the first gen Prius transmission. Planatary gear? Sounds similar to a CVT, the computer is always trying to optimize the gear ratio for the situation. Anyway, since you don't have a fixed ratio I doubt increased diameter will help.
http://ecomodder.com/forum/showthrea...ius-11426.html regards Mech |
Looking a little further I'm seeing the oe tires had a load rating of 84, and with the Potenzas I was thinking of only having a rating of 78, I wouldn't try that route anyway
I was going to say yoko avid ascends since they are llr and are not made with oil or food products, they use orange peels.
But they dont make them in 14 inch. |
I would also suggest these: http://www.tirerack.com/tires/tires....omCompare1=yes 75,000 mile rating, 11/32 tread depth, 14lbs Discount can order any tire you want, they only advertise a select few that they make higher margins on/ are more popular. For the same price of $57 you can go up to 175/70's or 185/65's and get load ratings of 84 and 86 respectively. |
Buy the best quality tires available. They will earn themselves back in lower drag, longer lifespan, better comfort and grip. Safety is priceless.
Keep summer and winter sets. (I'm changing back to summer tires next week). |
I've read that thread, and I didn't see anything about tires/size (it's about Aeromodding) |
I'll have to see what my local shop can get these AltiMAX RT43 for Size: 175/70R14Serv. Desc: 84T Load Index 84 = 1102lbs (500kg) per tire Speed Rating “T” = 118mph (190kph) UTQG: Treadwear: 600 Traction: A Temperature: B600 A B Price: $53.00 (each http://www.tirerack.com/tires/tires....RT43&tab=Sizes |
Discount Tire is the BEST !!!
looks like my local tire guy can get the AltiMAX RT43 to me for about $350 (out the door)
shipped, mounted, ballanced, with sales tax http://www.tirerack.com/tires/tires....RT43&tab=Sizes Size: 175/70R14 (Tire Rack charges $58 for shipping, and I'd still have to pay mounting/ballancing) I'm pretty happy with the deal they say these are better than any of the tires in (or near) this price range only tire thats really better are the Michelins (at $40 more each) |
Tire choice cost me 7MPG on my VX. I got a set of Michelins for $226 total from Sam's club. Bottom line is cheapest is usually never best, if it cost you hundreds more in fuel. Sorry for clogging up your thread with relevant information. regards Mech |
I'm thinking about following some of his tips/tricks this summer 7mpg, that's a huge loss I have seen tires make a difference, but never that much |
The original 15 year old tires were on my 94 VX when I changed them. I could't believe it myself. Just got the car painted and I did't want to risk a blowout with the old tires. I hope you have better luck than I did.
regards Mech |
they are advertised as a good quality all season tire (I've got "Snow" tires for the winter) honestly, I've only purchased tires for specific Performance aspects in the past (racing, snow, touring) never for economy at least, Discount Tire will stand behind them for me :thumbup: |
thats crazy I don't like tires that are over 5 years old tire shops in my area won't even touch (re-mount) tires over 10 years old |
http://ecomodder.com/forum/showthrea...tml#post171019
This is one of orange4boys threads on LRR tires from 2010. Hope it helps. The Kuhmo Solus tires on my Fiesta (factory) seem to be real good. One of the absolute best would be the RE92s they used on 1st gen insights, but they might not have the load capacity for your Prius with max capacity loads. regards Mech |
Here is the thread from orange4boy about the Nokians he put on his prius, said he loved them. Look at post 158.
http://ecomodder.com/forum/showthrea...-10710-16.html regards Mech |
I wouldn't advise it but I rode a 1971 Honda CB350 bike on the original tires in 2011, when they were 40 years old! I wanted to see if it was going to burn oil after sitting for 28 years before I bought tires that cost me more than the bike! Paid $250 for the bike sold it for $2500 with about $1100 total in it. Bought at 4718 sold at 6100, never had a light bulb replaced.
Pins and needles, never over 45 for 200 miles, oil level never moved, replaced tires, changed oil. regards Mech |
Happened into a set of Nokian WRG2's for the Stratus, nice tire, but expensive 195/65-15 are $120 range. Going to put a set WRG3's on the impala this summer/fall and any future cars that I expect to have around for awhile that won't have dedicated winter tires.
those are more expensive than the Michelins http://www.bridgestonetire.com/tire/potenza-re92/p175-65r14 couldn't find a load rating when I put in the car, nothing shows as being apropriate |
and the performance from a "winter" tire is amazing Nokian WR G2 185/65R14XL 90T BSW free shipping BSW Buy online - tires-easy.com http://www.tires-easy.com/cgi-bin/rs...n&typ=R-159423 |
RE92s were 80 each for me from Honda- that's the only way I'll go for the Insight, but if I had the Prius, it would either be RE92s (100k tire) or the stock tires for their price, and see how they do.
goodyear fuelmax P185/65R14 and you should be able to get a $40rebate
Goodyear Assurance Fuel Max Tire P185/65R14 - Walmart.com that makes them about $550 for the set the General's I ordered (should have them installed monday) were $65 each that's about $350 installed (after Labor and Tax) and they have a $100 rebate :thumbup: |
As rolling resistance data is closely guarded, one default you can assume is that the OEM rubber is the lowest RR you are likely to find. This is data the OEM has to submit to the EPA to get an MPG rating and as MPG ratings are often sales points, the OEM has a reason to use the lowest RR tires possible.
Keep the skinny tires. |
Big Dave,
I hope you understand that I am trying to correct a misconception and I'm not picking on you or your post. Just merely trying to get the facts straight. Quote:
And rather than get into a pissing contest with their competitors, they've chosen to be purposely vague. Quote:
Also remember that when talking only rolling resistance in same tire size effect to fuel consumption is only max 7-8% better fuel consumption between best and worst. Now you can easily make calculations is it worth to buy brand tires or not. Based on Finnish tire magasize tests usually it is as brand tires tend to last up to twice the miles longer.
I would not fully trush the wear ratings or what you think Capriracer is there some legislation that manufacturers cannot lie on that rating? If you open the door to changing size totally different the bigger diameter (longer distance travelled) and aerodynamics (narrow) effect more than the LRR compound. I would go for 175/80R14 if you can find a good set (if your state laws allow them). In finland you can find over 35 manufactuers for that size so there must be some importers to US also... At least in Finland you can buy used set easily 50-100$ so you can test their effect. If they dont work sell them and buy different size. |
The tire manufacturers can not OVER state the wear rating - and they have to do the comparison to a standard tire (so you can compare between brands) - BUT - not only can the tire manufacturers UNDER state the wear rating, they can run the test a number of times, selecting the best result (if they want). Or they can run the test such that the comparison to the standard tire is through multiple tests, taking advantage of the error in each test. So while you can compare treadwear ratings, you have to take them with a grain of salt. There is probably little difference between tires rated within 10% of each other (say, 400 vs 440), but there will be a difference between tires rated more than that (say, 300 vs 400) - keeping in mind that understating the wear rating is possible. Quote:
Rolling resistance can be bigger % change but the effect to fuel consumption is max 7-8% at least what I have seen in local magazines (been following the tests over 4 years perioid summer and winter tires) and they have usually one or two reference tires of chinese marks (non brand) just to see the level of their performance.
This years test had 16 tires and biggest difference was 6% to fuel consumption. and the suprice performer was Landsail LS288 which outrun few of the brand tires in some tests. That tire set reference price was 350€ 8.6 points of 10 vs winner Continental Contipremium Contact 5 550€ per set 9.5 of 10. tested size was 205/55R16 |
