EcoModder.com
-   -   tires rated for higher psi? (https://ecomodder.com/forum/showthread.php/tires-rated-higher-psi-11832.html)
moonmonkey 01-11-2010 10:10 PM
my 175/65r14 tires on my toyota echo are rated for max psi of 44 are there tires that have a higher psi rating? mine are the walmart goodyear viva -2's they are supposted to be llr (low rolling resistance) ,but they are no better than my old tires at least not yet and i have 30k on them.
orange4boy 01-15-2010 03:32 AM
I just bought a set of Nokian wrg2 tires and they are supposed to be LRR. They are working really well for me although I have not collected enough data yet. Incredibly quiet even on wet roads. Max 51 PSI with a canola silica compound. They have your size in an all season i3 I think. 620/A/A They are a very green comany as tire companies go. The first to offer non toxic tires.
Also there is the bridgestone RE92 XL which is an OEM for the fist gen Prius. They seem to be an OK tire and LRR. (50 PSI) Mediocre reviews though.
There is also the BS B381 which is the lowest RR tire going.
cfg83 01-15-2010 04:04 AM
moonmonkey -
I used tirerack.com to research tires rated at 51 PSI :
http://ecomodder.com/forum/showthrea...ires-2642.html
Mine don't seem to be available in your size, :( .
CarloSW2
Gasoline Fumes 01-15-2010 09:03 PM
The Sumitomo HTR 200 is available in a 175/65-14 and a taller 175/70-14. Max pressure is 51 PSI. It's no B381, but it's cheaper and available in your size. And it's one of Green Seal's recommended tires. I wish they made them for 12" wheels. :(
