Old 11-23-2009, 10:23 PM   #1 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Metroids: rust repair panels!
Not a huge selection, but if you can fix your ball joint and frame reinforcement on your own, here are some rust repair panels that should make the rest of your restoration easier:
Rust Repair Panels: Suzuki Swift/Chevy Geo Metro 1989-1994
The Following 2 Users Say Thank You to Christ For This Useful Post:
Johnny Mullet (11-24-2009), wyatt (11-23-2009)
Old 11-23-2009, 11:31 PM   #2 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
I really need to fix the rocker panels on the right side, and they should be done on the left. I haven't been able to find them online, so I was considering trying to do something out of fiberglass after getting rid of the rust that exists... but this would be better! Thanks!
Honda Insight Under-body Smoothing Panels (custom belly pan / undertray) 3-Wheeler Aerodynamics 81 03-30-2018 09:44 AM
Replacing metal body panels with plastic silverhawk_184 EcoModding Central 8 12-07-2010 07:18 PM
Replace sunroof with solar panels to power AC? Luxbg EcoModding Central 6 08-19-2009 10:23 AM
Solar/PV panels alt delete cost effectiveness? theunchosen EcoModding Central 11 04-17-2009 08:32 AM
Rust repair panels for 92-95 Civic Hatchbacks TomO Off-Topic Tech 6 11-16-2008 12:33 AM
