Torque for Android review
http://i1220.photobucket.com/albums/...h/Torque01.jpg
Well, I've had torque for almost a week now and I'm quite pleased with it. Mostly my time has been spent trying to figure out which gauges in what sizes and what locations would be the most useful. I had some disconnection problems that I couldn't figure out until I found that my left foot managed to hit the OBD scanner. The scanner itself is small and if I find this to be a continuing problem I'll just move the connector. http://i1220.photobucket.com/albums/...h/Torque02.jpg When you select "Realtime Information" it takes you to a screen that's full of gauges and looks great, but at arm's length while driving is too busy to be useful. That's fine because changing the screen is easy, and there are seven screens that you can drag between. Having gauges or groups of gauges readily available but not taking up screen space all the time is a great feature. http://i1220.photobucket.com/albums/...h/Torque05.jpg There are several types of display. Here are Dial (Round), Graph, Dial (Meter) and Digital Display. Each one is useful in different ways. Note that the three displays that give hard numbers are all off a bit. It looks like there's a little slop between all the widgets taking readings from the car. That's going to happen, and the revs were fluctuating- I had just started the car so that the gauges would have something to read for the screenshots. http://i1220.photobucket.com/albums/...h/Torque03.jpg After four days of commuting with it, this is the screen I'm using right now. I just threw the coolant in there because it was "extra" space. We'll see how it goes. It could even go to HUD mode, but I think that's more of a clever developer trick than a useful feature. http://i1220.photobucket.com/albums/...h/Torque04.jpg Raw Data display http://i1220.photobucket.com/albums/...h/Torque06.jpg The stunningly useless "Eco Warrior." It adds leaves to the tree as your driving becomes "greener." Get it? http://i1220.photobucket.com/albums/...h/Torque07.jpg Options while in the display screen http://i1220.photobucket.com/albums/...h/Torque09.jpg The "Add display" menu http://i1220.photobucket.com/albums/...h/Torque10.jpg Settings http://i1220.photobucket.com/albums/...h/Torque11.jpghttp://i1220.photobucket.com/albums/...h/Torque12.jpg Data logging settings http://i1220.photobucket.com/albums/...h/Torque13.jpghttp://i1220.photobucket.com/albums/...h/Torque14.jpg Sensors that Torque will display, if your car has the sensors: Quote:
I'm glad I got Torque. It's going to help me be more effective at hypermiling. I just hope that I bet right on which Bluetooth OBD2 scanner to buy, because if I didn't then I'm buying another one. This app is worth it. |
Awesome review! How much is the app?
The app is like 5 or 6 bucks, but there's a free version, then you have to get the scanner that's $44. Just ordered one to try it out since I got a american express gift card from work. I'll be using it for work since I drive to locations for jobs, so I bet I can write it off as a business expense. :P How accurate is the mileage widget? I love how my car tells my mileage and hopefully now I can do the same for my truck in real time.
The mileage is accurate. When I started with it I had instant and cumulative on together and they were both in line with my car's display, which is really close to what the odometer and gas pump agree on.
The app itself was less than $5, some oddball number because the developer is British and probably prices it in Euros or something. I spent $49 on the bluetooth ODB scanner. One more thing- Your phone still works while Torque is running. Incoming calls aren't a problem and the default setting is to remain running in the background when you leave it, so any logging isn't interrupted. I'll leave any study of the logging features to the next guy, but I do like returning to an app in progress more than starting the app up all over again. If you're using your truck for work, the logging can probably help you deduct a little bit more than the price of the scanner & app. A pile pf receipts with log data is always better than a pile of receipts. That could really be worth looking into. |
Awesome !
I downloaded the free version for now. Hope my ebay module works. If not I'm only out $18. This could give a Scangauge II a run for the money. I can pick up a Nook color for <$200 and root it. Hmmm....... |
They do now: Nook Color Can Now Use Bluetooth For Keyboards And SIP Calling
There are also ODB scanners with USB output. That falls into the "I don't see why it wouldn't work" category, but I don't see why not. I asked over at the Torque forum if anyone has done that yet. |
Well, now I see why not. Ian Hawkins answered me pretty quickly.
In a thread about MPG calculation someone posted a picture of their display.
If you're at all curious, the Torque site is here. |
The answer for Android USB is here: Android ADK. Of course it's not fully implemented yet and will only support newer devices, but it's a start.
I recently had to remove my MPGuino to fix some engine warnings (where I spliced the wires was getting loose and the wires themselves were starting to rust) and I've been meaning to check out alternatives. I think I may go this route. Thanks for doing the review :thumbup: |
