Toyota Camry Gen2 1989 Aero Recommendations?
Just wanted to know what you guys would recommend doing first. I'm not interested in doing damage to the car, but I wouldn't mind adding a few things onto it to make it more aero dynamic.
This isn't mine, but looks just like it: http://photos.carsguide.news.com.au/...Z904/1_600.jpg http://images03.olx.com/ui/2/85/49/23197649_1.jpg http://farm3.static.flickr.com/2319/...dfcf51.jpg?v=0 I was thinking about doing something to the front bumper / grill using some aluminum in the 1/8" to 1/16" range. What would you guys do? I typically drive very short distances under 5 miles usually so my MPG sucks usually. But 1/2 the miles are on the freeway, so I thought I could benefit a little from some aero mods, and I'd really benefit on the occasional longer trip. Thanks! :thumbup: |
Camry
looks like the front airdam could be lowered about 3-inches(75-mm),and then that elevation could carry all the way down the rocker panels,and behind the rear wheels to the back of the car.I would trim back the mudflaps so they don't tear at the flow.A rear deck spoiler on the trunklid,rising up and to the rear at no steeper than a 30-degree angle,and tall enough that a long straight-edge laid across the back of the roof and spoiler top indicated an angle no steeper than say 12-degrees as measured from the horizon.Your wheelcovers are very good,I'd hang on to those.If the lower grille opening appears to have "overkill"(way too much opening compared to rediator width) you could close off some of the outer portion of that opening.------------ Your short commute is a killer to mpg,it takes 22 continuous miles of driving just to get all your lubes up the equilibrium temp.If you could magically pre-heat your engine,transaxle,and all bearings,you'd see remarkably higher mpg.
When I go for updates or modifications, I change or replace the bumpers so that the car will look bulky. I also change the color and design of the car to give it a new and refreshed look.
Lower it.
Check out my Gen4 Camry thread under aero area...
I know that costs $$$. Thats the reason I have a 10 yr old Camry and not a 5 yr old Prius. Pete |
