Transmission wear from P&G (pulse and glide)?
Hello all, I'm wondering if anyone has experience with prematurely wearing out a manual transmission from constantly shifting in and out of gear.
I used to only shift to neutral on decently long/steep hills (perhaps 10 or less times per day on my daily commute) and got 42-43 MPG average. However, last tank I experimented with shifting to neutral while going down every hill and I averaged 49 MPG over the tank for the first time. Very nice! :thumbup: My previous best was 45.4 MPG over the tank and that was under better traffic conditions, so the new strategy seems like a massive success. My only concern is that shifting to neutral on every hill is a LOT of shifting, there is no flat ground where I live. There's constant small hills and I drive ~50 miles per day, mostly on country backroads. I sort of worry that I could eventually wear out 5th gear from shifting in and out of it constantly. For what it's worth, I always blip the throttle before shifting back into gear to speed up the transmission's input shaft to as close to the required RPM as possible as an attempt to minimize synchronizer wear and, to a lesser extent, clutch wear. I'm not too worried about the clutch or its hydraulics since that's not a big deal for me to replace, but I don't want to excessively wear the transmission's internals. Anyways, I would like to continue to experiment with different coasting and P&G strategies, but only if doing so won't excessively wear my transmission. How concerned do I need to be about this? Have any of you had premature transmission failures as a result of frequent shifting? Thanks very much in advance as always! |
I haven't heard of, or experienced transmission problems from P&G. The only excessive wear I noticed on my Civic Wagon was the ignition switch. And it was old enough to have issues from normal use anyway.
I always clutch it, and people tell me I’ll wear it out. By my estimation, clutching had to occur anyhow to get into neutral. Might as well keep it pushed in and avoid the synchro wear.
I can think of 2 downsides to coasting by holding the clutch instead of shifting to neutral. Obviously there's the leg fatigue and potential clutch/release bearing/thrust bearing wear. I think there would also be somewhat more drag than in neutral since the entire transmission/input shaft assembly is spinning rather than just the output side, but how significant this drag is I'm not sure. |
Keeping the clutch pushed in (with the engine running) causes more wear to the clutch release bearing and the crankshaft thrust bearing. I don't want to be the one to find out if it's a significant amount of wear!
If you blip it after you push the clutch in it won't spin the input shaft unless you have some clutch drag. |
My recollection was that in Oregon, one can coast downhill in neutral in cars, or clutch in only in trucks,but...
Stack Exchange says Quote:
Not a primary source, that would be the DMV, but the article lists a number of other States as well. When I worked at a feed & seed company in high school. I knew a driver that could shift the International truck up and down through the gears without the clutch. |
