EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   Treadmill powered pusher trailer for bike (https://ecomodder.com/forum/showthread.php/treadmill-powered-pusher-trailer-bike-21812.html)
lumberjack_jeff 05-07-2012 01:48 PM
I have a 1.25 hp permanent magnet DC motor from a treadmill that I'd like to use in a bicycle pusher trailer.
What is the best way to do this? Since I have the PWM circuit board from the treadmill, it seems that I could simply install a 12v battery and an 1000w inverter on the trailer, and a throttle potentiometer to the handlebar but I'd like a more elegant solution, partly because the controller has behaviors baked into it for treadmill use such as a delayed soft start, and partly because I'd like to skip the inverter.
Ryland 05-07-2012 02:27 PM
If it's a 110v DC motor, then you can get a Kelly Controller, they are a cheap, Chinese made controller that tend to be under built and they self destruct of you push them at all to their limits, but they do make a 120v (18v to 136v) 100 amp (40 amps continues) speed controllers that they sell for around $300, so while I wouldn't normally suggest that a Kelly controller be used, their 100 amp controller would handle 16 peek HP for one minute, and 6.4HP continues, so it would be way more then you would need on a bicycle.
At that point you would just need a high voltage battery pack, a high voltage pack is going to give you slightly better range because of less line loss at the higher voltage.
Depending on your speed, it seems like bicycles tend to use 15 to 30 watt hours per mile, the faster you go the more energy you use, so lets say you get 10 12v 10amp hour lead acid gel batteries, that's 1,200 watt hours, lead acid gel batteries can handle slightly deeper discharges then flooded, so figure to 80% depleted you have around 30 mile range at 30 watt hours per mile, if you end up only using 20 watt hours per mile then you have a 50 mile range.
You could of course do some crude testing with your motor and a 12v or 24v battery pack and a simple switch to see how much push it gives you at a lower voltage to see if you could get away with running it at 72v or even 60v if you only want to go with 5 12v batteries, it would give you less speed, range and over all power, but it might be enough to fit your needs, or you might find it to be completely gutless, but it would let you find out without a huge investment in batteries and a speed controller.
jkv357 05-07-2012 03:21 PM
Here's another company to consider for a controller - Alltrax Products Page
We are using a SPM 48400 for an EV project (36V w/Mars motor). Fully programmable for all sorts of functions. Good people to deal with and knowledgeable customer service if you have questions.
Jay
Ryland 05-07-2012 03:49 PM
I have an Alltrax controller in my electric car and I really like it, but alltrax makes low voltage high amperage speed controllers, their highest voltage controller is 72v and 200 amps costing about $450 on Ebay for their 300 amp two minute rating, (200amp 5 minute, 125 amp 1 hour) speed controller, granted their specs say the 72v controller can handle up to 90v but my 48v speed controller says it can handle up to 60v and if I pull the charger off and try to drive I have to wait till my 48v pack rests for a few minutes and the voltage drops down to 56.4v before the controller will power up due to over voltage protection, so I suspect that the same will hold true for the 72v speed controller, that it would never turn on if you had say a 84v pack.
So if you want to try running a 110/120v motor at only 72v you might still get almost 1hp out of it and you are going to have a much better quality speed controller that is made in the USA, but if you want to get the max speed and power out of your motor that is possible you are going to need to be able to run it at 120v, your other option of course would be something like the Open ReVolt speed controller, 144v max and 500amps, but that would be a speed controller on a bicycle that is powerful enough to work on your car.
Testing your motor on a 12v and 24v battery pack without a speed controller, like I said is going to give you a better idea of what you can expect from that motor at lower voltages, you might find that it has plenty of power or you might find that at 12v you can stop it by grabbing the motor shaft.
MetroMPG 05-07-2012 04:57 PM
When I read this thread title, I thought it was going to be about a person on a treadmill on a trailer, all of which was somehow powering the trailer to push the bike.
Nope.
ecomodded 05-07-2012 05:14 PM
That would be funny as hell to see a guy running on a treadmill to power the trailer to push the bike.
A bicycle built for two.. one rider , 1 runner.
I would mount the motor on the bike and tow the batteries. It just seems like you would have much better control / steering.
BenjaminT 05-07-2012 06:57 PM
This.
Jeff, any deviation in the trailer's center of thrust, including differences of traction, will try to push the rear wheel off-track. Powering the cart with one motor would mean a differential is necessary. By the time all is said and done, you would be better off having built (or bought) a badass e-bike with additional battery capacity in the trailer, as Ecomodded suggested.
edit: I'm not saying it can't be done, but. You would need traction control of some sort to make it safe.
Frank Lee 05-07-2012 07:50 PM
Is this known from experience or speculation?
Grant-53 05-07-2012 08:09 PM
The pusher trailers I've seen online are two wheelers with hitches mounted to the rear drop out area. I'd go for a frame mount motor. If you are planning for low speed torque, use a parallel battery connection. Is there an rpm rating on the motor?
Electictracer 05-07-2012 08:58 PM
I have seen one of these trailers with a purely DC system. You don't want to jam the throttle with the trailer cocked sideways with around 1000w of power, but otherwise there were no control issues. Gas powered trailers like this are very common.
