EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Tufts develops regenerative electromagnetic shock absorber (https://ecomodder.com/forum/showthread.php/tufts-develops-regenerative-electromagnetic-shock-absorber-6173.html)
MetroMPG 11-25-2008 04:46 PM
Via GCC:
Tufts University has developed an electromagnetic shock absorber that apparently has some really good energy generating potential:
At the SAE Government/Industry Meeting in Washington in 2001, Goldner, Zerigian and J.R. Hull from Argonne presented a paper estimating that the percentage of recoverable power/energy for a 2,500 lb vehicle that employs four optimized design regenerative magnetic shock absorbers and whose average speed is 20 meters/s (45 mph) on a typical US highway is likely to be between 20% and 70%.
They're claiming that this 2500 lb vehicle can generate an average output of 1-6 kW "traveling at relatively moderate speeds on typical roads encountered under normal urban driving conditions."
Source: Green Car Congress: Electric Truck Exclusively Options Regenerative Magnetic Shock Absorber Technology from Tufts
SAE paper: http://www.osti.gov/bridge/servlets/...ive/771018.pdf
FastPlastic 11-25-2008 05:32 PM
I was wondering when someone would look in to this. It ran through my head at one point. Just wasn't a project I could take on. Got the idea from those little rechargeable flash light that you shake. Just in a much larger scale.
The amount of force those shocks see is enormous I'm sure. I think it has the potential of increasing the range of any vehicle with an electric power train immensely. It would also be something that could be retro-fitted to an existing vehicle if done right.
captainslug 11-25-2008 06:25 PM
Same principle as wave generators.
MetroMPG 11-25-2008 06:37 PM
Considering a small car only requires around .3 kW to run (not counting lights, stereo, etc), these 1-6 kW shocks could conceivably supply all the vehicle's power needs and then some, permitting the alternator to be off most of the time.
cfg83 11-25-2008 07:13 PM
MetroMPG -
That's what I was about to say. It could be used for regular cars and hybrids for increased range/electrical charging.
CarloSW2
NeilBlanchard 11-25-2008 08:16 PM
...so you pray for bumpy roads? :D
Great idea!
cfg83 11-25-2008 08:30 PM
NeilBlanchard -
Great idea!
The irony is, I drive the 710 freeway in LA for my commute, which I like to call "Diesel Alley". This is *the* freeway between the Long Beach Harbor and the rail yards in LA, so it's uber-buckled from truck traffic.
On that disaster of a road I could probably generate 4KW!!!!!!!!!!!
CarloSW2
metromizer 11-25-2008 08:34 PM
If you commute on northern California hiways like I do, there's no need to pray ;)
For a non-snow belt area, my state's hiway maintainence org has no excuse... other than being broke that is
NeilBlanchard 11-25-2008 08:37 PM
I live in New England -- say no more! I think we invented the frost heave...
jamesqf 11-25-2008 09:53 PM
Oh, it can get worse :-) I only drove the Insight on I-80 over the Sierra one trip, because I was afraid that I was going to high-center it on the ruts the truck traffic had worn into the concrete.
