Ugh! The DOT is killing my gas mileage!!
The DOT has just finished building a new road into the main town where I live. The old road was a highly congested two laner which straddles a river and a mountainside. This road was fine with me because I could go at a leisurely 45 mph without disturbing traffic flow.
The new road is 55 mph, much wider, and slightly shorter. This would not bother me, but the biggest problem I have with it is the new layout. To get on the new highway, I will have to stop and make a left turn at a stoplight. This stop light is at the base of a giant hill. I used to be able to EOC down this hill (it was the longest EOC on my trip). Now I will be forced to come to an abrupt stop, losing about 60 mph worth of momentum. On the return trip, I will have to stop at the traffic light and make a right turn. Then I have to start up the hill from a dead stop. This sucks. Haven't these people heard of on/off ramps??? |
Well,
That makes three snippy comments with "hippy" used as an epithet. It's getting old really fast... To the OP: if you downshift and use the engine to brake, you'll get the maximum mileage on the hill -- but obviously, this is still not as good as coasting a long way. |
Hi,
Gee, I wasn't acting like the world revolves around me. Yeah, it's a little frustrating but I will be able to deal with it.... |
Any chance you can learn the timing of the light and hang it out on that left turn? Brake a little early rather than a lot and late, and carry a higher momentum through the light of course (assuming good timing)
I think my best shot will be to hopefully gauge the light that goes directly across and take the same route I have always taken. I can maintain full speed through that light if I get lucky. It's just unlikely to be green very often :( Looking at this with the glass half full, my old route is likely to be much less crowded. Though traffic was never close to a grind or standstill, it was substantial enough to hinder P&G. |
Hippies? Maybe.
Trying to save money on gas with a little passion and science? Yes! Damn road construction. Lights are better than stop signs in most situations if you can time them, but there are some looonggg red lights out there. |
