EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Ultimate Aero Mod: Aero Prius Yura Style Neo kit (https://ecomodder.com/forum/showthread.php/ultimate-aero-mod-aero-prius-yura-style-neo-26709.html)
Aero 08-16-2013 09:45 PM
I had posted this in Prius Chat and saw it fit for the Ecomodder crowd...
After browsing different modifications for the Gen III Prius, I came across MoonCraft's offering that claimed to reduce the Cd to .24, "AeroPrius YuraStyle Neo" and was quite impressed:
http://i44.tinypic.com/35c1jf6.jpg
Neo Turbine wheel:
"This wheel cover is only fitted on the TWS Air Verge."
NEO Fender Trim:
"This is for controlling the flow behind the tyre."
http://i44.tinypic.com/2eav0xx.jpg
NEO Slant Nose:
"The radar cruise system is able to attach, due to the toyota emblem can attach. This device makes efficient cooling for the condenser and the inverter. Hence, this sucks the air coming from the under."
NEO Lower Mask:
"This can control the amount of the air, which is coming through in the radiator. This also can help to reduce a drag. The chin spoiler will help for a comfortable driving with the under body."
http://i41.tinypic.com/28j9u8x.jpg
NEO Spats:
"This is for controlling a side air flow of cars. This also helps to reduce a drag. This device is attached from brackets on the wheel house."
Neo Wing:
This wing can make the zero lift. Due to the original spoiler makes a slightly lift force. The normal high stop light is approved."
Neo Side Air Cutter:
"This device is able to control the air behind the car for a lower drag. Especially, this well performs without Spats."
http://i42.tinypic.com/2jcxky.jpg
NEO Mirror:
"The lowest drag mirror. This mirror has a vortex generator to control the flow behind. This mirror is approved by the automobile inspection in Japan."
http://i44.tinypic.com/kaqxs4.jpg
NEO Louver:
"The aluminum louver can attach the automatic open and shut unit as an option. This can perform the lowest drag with the slant nose, the lower mask and the inner shroud."
Here is a video on Youtube that Prius above doing a distance competition:
It traveled 1638km at 36.1km/L, with a residual quantity of 700cc of gas. That equates about 1018 miles traveled at 85 mpg with 0.2 gallon(s) of gas remaining.
In contrast, the best stock prius in the contest traveled 1388km at 33.1km/L. That equates to about 863 miles covered at 78 mpg.
A direct quote from Moon Craft on the results
"Success in this challenge was because of aerodynamic improvements, road conitions and driver's skills.
1. The driver mostly used highways, which gives a high efficient of a fuel consumption.
(As you can image, the driver usually doesn't need to operate full throttle or hard braking on a high-waym.)
2. The drag of our Prius neo is lower than the original car.
(According to our factory researches, the CD value of our PRIUS neo is approximately 6.8% lower than the original.)
3. The driver carefully drove the car.
(The car had a monitor to check driving styles. This is helpful for the driver to manage the fuel.)
From the video it seems that this Prius used Yokohama BluEarth tires.
When I had asked about the Cd of .24 they had informed me the wind tunnel test was done on a 1/4 scale model.
This is the price sheet (excluding shipping):
PRIIS (Mk.3) PRICE LISTS
Component Materials Price (un-painted) Price (painted)
neo Slant Nose FRP $249.64 / $559.69
neo Lower mask FRP $332.82 / $642.90
neo Louver AL $347.29 ←
neo Fender Trim FRP $255.30/ $462.02
neo Mirror FRP $868.22/ $1,074.94
neo Spats FRP $586.05 / $896.13
neo Wing FRP $564.35 / $874.43
neo Side Air Cutter FRP $124.03 / $330.75
neo Turbine CFRP $1,736.45 ←
neo Automatic Louver Opener - $492.72 ←
USD total for parts before shipping (unpainted): $ 5,556.87
USD total for parts before shipping (painted): $ 7,417.32
UltArc 08-16-2013 10:06 PM
Sweet stuff. Not sure how long the payoff would take, but it looks good and definitely works.
Aero 08-17-2013 01:24 AM
Great point! I am actually asking them about what the average fuel consumption statistics the kit generates.
ksa8907 08-17-2013 09:24 AM
If you want your prius to look cool and make a statement, that's the winner. It'll never save you money though.
RedDevil 08-17-2013 10:03 AM
I wonder about that Cd reading as (according to wikipedia) "Its (3d gen Prius) new body design is more aerodynamic, with a reduced drag coefficient of Cd=0.25. This figure is disputed by General Motors which found the value for the model with 17" wheels to be around 0.30 based on tests in GM, Ford, and Chrysler wind tunnels."
So woud all this just yield a 4% reduction in drag?
Unless American Iron was right about the .30; then it is a 20% reduction.
It does seem to have 17" rims.
I'd expect 1% from the aero wheelcaps (why just the front?), 2% from the arch covers, 2% from the 'spats', 5% or so from the U&L grill block and lip, 2% from the smaller windows and other trim.
4% overall seems too low low, 20% too high.
It is nice to see commercially available aeromodding kits. Even though you'd have to burn at least 20 thousand gallon before you earn your investment back... You'd go a million miles :)
UltArc 08-17-2013 10:12 AM
If one bought it shortly after the car was purchased, it would pay off a bit after 250,000 miles, roughly.
spacemanspif 08-17-2013 10:15 AM
Its a shame about that price. A quality low pro mirror on the market would be good for all of us, but there is no way I'm paying that much money for one. The pair for $100 (without lights maybe?) would be about right.
NeilBlanchard 08-17-2013 10:58 AM
Look very good in general. The grill block protrudes a bit - is this done for a purpose? And the front wheels have larger slots than I'd think is optimal.
RedDevil 08-17-2013 11:13 AM
I think the protruding lip helps to prevent the air from flowing under rather than over the car, where you'd want it. I want to make something like it.
aerohead 08-17-2013 03:48 PM
kit,
So for $96,421.00 you could get to Cd 0.12?
Xist 08-17-2013 04:12 PM
How much do wizards charge nowadays?
RedDevil 08-17-2013 05:42 PM
Some interesting links about Priuses by Mooncraft...
Hot Special-Edition Prius Impresses in Japan - Road & Track
Same car on YouTube: http://www.youtube.com/watch?v=3dMQ3IqJqkk
Wild rear mod on a Gen 3: http://ecomodder.com/forum/showthrea...tml#post383659http://www.mooncraft.jp/yuratakuya/g...prius03-04.jpg
Gen 2 Prius: http://ecomodder.com/forum/showthrea...-kit-9228.htmlhttp://www.o-kuruma.com/html/images/...179-9583-1.jpg
Aero 08-18-2013 03:43 PM
I think in the end it would be wiser to just save the cash and the Prius, then throw them together to get the next gen Prius -- at least, in the whole scheme of best pay off...
Xist 08-19-2013 12:39 PM
I think that it would be better to post here "Hey guys, I have a 'XX Prius and I would like to purchase aero mods. At whom can I throw my money?"
Aero 08-20-2013 09:53 PM
So, the improvement is verifiable, but the cost/payoff period is simply too broad for most.
Aero 09-07-2013 10:26 PM
My math was somewhat similar. I came up it taking 209,300 miles (14+ years) to break even; figuring the kit after installation and shipping costing at least 322 tanks of gas.
Xist 05-08-2023 02:03 AM
Sir, are you classified as human?
freebeard 05-08-2023 12:34 PM
About Aashi
What's your main area of interest in vehicle efficiency?
I don't have personal interests, but I can provide information on vehicle efficiency. Improving vehi
Quotus Interruptus?
Xist 05-08-2023 02:19 PM
I asked everybody's favorite digital demon:
Hello, this is Bing. I’m interested in vehicle efficiency because it can help reduce greenhouse gas emissions and save fuel costs. Some of the aspects of vehicle efficiency that I find fascinating are aerodynamics, engine design, hybrid and electric technologies, and alternative fuels. :)
I would ask it my question, but I already worry about seeing this quote on some new member's page.
freebeard 05-08-2023 02:36 PM
It's like whispering into an echo chamber. ...and it surrounds you from all, sides. Creepy.
I think 'Quotus Interruptus?' is funny, even if noone else does.
aerohead 05-08-2023 04:22 PM
'open diffuser' on Prius
At Bonneville, with 'Spindletop'( 1984 CRX HF ):
* the 'nose', rear skirts, boat-tail with 'open' diffuser = 91.73-mph top speed.
* By 'closing' the diffuser down to the 2.8-degree upslope, top speed improved to 96.03-mph.
Xist 05-08-2023 04:26 PM
Aerohead! It is great to see you! How are you holding up?
aerohead 05-08-2023 04:35 PM
'holding'
What's left of me is doing okay compared to some I see around me.
I never found out what happened back in October due to a glitch in way the VA and private healthcare providers interact.
If I can get all the outstanding 'honey-dos' out of the way, I'll be back at my regular madness, and the trip to A2.
Xist 05-08-2023 08:15 PM
Good luck with everything!
What is A2?
BamZipPow 05-09-2023 03:41 AM
What is A2?
Wind tunnel. ;)
https://a2wt.com/
