Ultra efficient boats
I thought this might be a good place to ask.
Has anyone ever found info on tiny, super fuel efficient watercraft? People brag about 5mpg (or nmpg ) in their cruisers but I'm CERTAIN there must be misers out there who have managed to squeeze much better out of tiny, aerodynamic, underpowered ones. Anyone? |
Welcome to Ecomodder.
...tiny, hydrodynamic, underpowered ones? As usual, the use case is a constraint. Speed/range, capacity, deck area. Here's a technique for massive ships that should scale down: KRISO Technology for Ship Propulsion Efficiency Improvement and Propeller Noise Reduction Catamaran for deck area. www.youtube.com/results?search_query=tech+ingredients+catamaran https://www.youtube.com/watch?v=6BMskpsLiYA How Many Solar Panels Do You Need For A Trolling Motor? klbuckyians.blogspot.com/2009/03/mechanical-jellyfish.html Quote:
Those are excellent starts, thanks! I'm surprised i didn't have an account here already, I've been tweaking my Insight and other vehicles for years based on threads here
Cutting sailboats seem pretty natural to mention, but part of my hairbrained motive was to convince my partner we should look at house further along the coast and get a commuter boat into Vancouver, BC, to evade the horrible traffic (and avoid living in a tiny cramped condo close to her workplace). That idea died when I read about the fuel efficiency of boats at more than a crawling/wind pace. But my curiosity remains |
So.... two to four passengers, short range. All weather year round performance.
Would you have a boathouse on the home end? M-hull: Quote:
I was perfectly happy with the acceleration on my old [1961] VW van.
Extractor exhaust, dual Solexes, a really low first gear and it weighed about as much as a Beetle. The (hole shot) 60ft times were awesome. (30mpg) |
https://blogger.googleusercontent.co...%20direito.jpg https://blogger.googleusercontent.co...%20Vanessa.jpg Roughly the same engine, with a higher compression and port-injection, at that stage the power increase was around 42% still within the 1.0L class. A port-injection with the low compression was already rated at a 20% higher power than the older engine fitted with a TBI, but even the high-compression engine was already pointed out as underpowered. https://blogger.googleusercontent.co...%20Vanessa.jpg https://blogger.googleusercontent.co...%20Vanessa.jpg I still remember when Ford only offered the 4-cyl 2.2L turbodiesel in the Ranger on fleet-specific versions, supposed that most customers would prefer the 5-cyl 3.2L turbodiesel instead. Nowadays most of the times I see a Ranger it has exactly the 4-cyl... https://blogger.googleusercontent.co...%20Vanessa.jpg |
This thread needs to start by constraining the topic to the requirements.
These have piqued my interest, especially since my local reservoir allows battery powered vessels. https://res.cloudinary.com/lift-foil...80p_fxq07f.jpg |
