EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Under belly pan (https://ecomodder.com/forum/showthread.php/under-belly-pan-11103.html)
Buddy 11-21-2009 10:40 PM
Under belly pan
I'm considering using aircraft aluminum to make removable panels under the vehicle. What thickness do some of you recommend? Thanks!
Cd 11-22-2009 01:02 AM
I made an engine cover out of aluminum flashing that I riveted to aluminum bracing.
It rattled and made all sorts of weird noise when the car was at idle.
I went to a thicker aluminum ( about the thickness of a dime ) and that solved the problem, but the thing is surprisingly ....heavy !
I would suggest using coroplast. There are several members here that have used it successfully.
It weighs much less.
( And one more thing - coroplast doesn't have razor sharp edges either :) )
FastPlastic 11-22-2009 03:20 AM
Awww come on, sounds like a great anti theft device to me. Don't have to worry about anyone hiding under your car.:D
I folded the edges over and glued them on mine. Hardens the edge up a bit and keeps it from being razor sharp.
stevet47 11-22-2009 12:44 PM
For something like a bellypan that requires a lot of cutting and fitting and contouring around uneven surfaces, etc. I agree that coroplast is probably the easiest way to go. Maybe just use aluminum right by the cat.
Buddy 11-22-2009 03:59 PM
Thanks CD! I assume that colorplast is cheaper than aluminum and easy to work with.
Buddy 11-22-2009 05:07 PM
CD - I Googled colorplast and found a company that makes it: there were 30 different materials available, not to mentioned thickness choice - yikes! Any recommendations?
Bicycle Bob 11-22-2009 05:42 PM
Election signs. Or, the same stuff, as commonly available at lumberyards.
thatguitarguy 11-22-2009 08:04 PM
I bought some Coroplast last week for about $13.60 per white 4x8x4mm sheet. Closer to $17 for colors. I first called a number of sign shops, because they use the material for signs, and I was hoping to recycle some old signs, but nobody had used stuff, so I asked them where they got their materials. A few different sign shops gave me some contact info on a few different suppliers, and the place I ended up buying from had a lot of different sheets of a lot of different materials, but they seemed to deal mostly in raw materials for sign makers. Look under signs and plastics. Good luck!
Weather Spotter 11-22-2009 08:18 PM
I got mine from a sign shop, $30 for a 4 x 8 sheet.
gone-ot 11-22-2009 09:01 PM
...put strengthening "creases" in ALL flat panels (like airconditioning ducts have) to halt 'tin canning' due to turbulent air flow and mechanical vibrations.
