If you see me on the road...this is what the front end should look like...added some Tyvek tape fer reinforcement just in case.
Finally fixed the damage from this spring with a metal bracket and bolted it up to the extender. Should hold up better than the zipties I had on there.
Blocked the remaining opening in the grill with some pipe insulation, Tyvek tape, and some aluminum tape just fer looks. It can be easily pulled off if needed to bring it back to a 67% block.
