EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   vacume guage & scanguage question (https://ecomodder.com/forum/showthread.php/vacume-guage-scanguage-question-27901.html)
dmafanp 01-03-2014 01:43 PM
excuse my ignorance im new to combustion engines, i want to install a vaccume guage so i can monitor my engine closer and so i can accelerate at the most efficient rate, if i set my scanguage to MAP will this give me the same kind of readings the vaccume guage will give me? thanks !!!
Daox 01-03-2014 01:57 PM
Yep.
Most cars can give you an actual load as a percentage of power, its LOD on the SG, dunno about the UG.
dmafanp 01-03-2014 01:58 PM
are LOD and MAP close to the same thing ?
Daox 01-03-2014 02:17 PM
It depends on the ECU programming. Some engines give you actual engine load as a percentage of power currently available. Some report the load of the engine versus maximum power output. I think most are the former.
