vacuum gauge reading problem
Today I hook up my vacuum gauge and reading is not steady. It's fluctuating between 20"-22" at the idle and even more during acceleration. I can't read when needle is jumping like that. What could be wrong?:confused: Any help would be appreciated.
You might find though, that it smooths out at high-rpm. :D |
I have tried vacuum gauge on my brother '92 corolla(4 cyl.) and reading were steady
It's possible that you have a leaking valve, incorrect valve clearance or a worn camshaft lobe. Does the engine run smoothly?
One way to make the gauge steadier is to put a restriction in it. I did that by putting some wire insulation stripped from a wire into the vacuum hose. It has to fit snugly in the hose. Another possibility is to stick a threaded stud or a bolt with the head removed into the hose. It works best if there is a long length of vacuum hose between the restrictor and the gauge. |
Put a small needle valve (available from Home Depot) in line with the gauge and start closing it until the gauge stops "fluttering". Or lubricate the gauge mechanism with a very high viscosity grease. I recommend the valve approach.
Is it possible to have too loose or too tight(from factory) valve clearance after only 58,000 miles? I don't hear any loud valve noise, just ticking.
Cars engines have a lot more sound insulation to them, so even a very quiet noise could mean loose valves. Though really, valves that are less than half of the spec range loose, (eg, range of .006-.010 and valves are at .012), is good for low end power and fuel economy. Tight valves don't make noise, and that's when you should worry. |
Is the gauge glycerin filled? That would stop the majority of the needle fluctuations. Installing a needle valve would probably alter the vacuum reading, something you want as accurate as possible. Anyone here use a Wika vacuum gauge?
I connected my vacuum gauge in two different cars and it works good ad smooth. Now, I know 100%, there is something wrong with my engine not with the gauge.
Copyright ©2000 - 2022, vBulletin Solutions Inc.
