Valerie Got a Nose Job
I've been bored recently and had some materials to play with.
http://img.photobucket.com/albums/v4...e/IMG_3546.jpg http://img.photobucket.com/albums/v4...e/IMG_3550.jpg http://img.photobucket.com/albums/v4...e/IMG_3588.jpg I had to angle it upwards a bit because I still need to get in and out of my driveway. Looks like I've barely got clearance: http://img.photobucket.com/albums/v4...e/IMG_3570.jpg But overall, not bad for a few hours work I think. http://img.photobucket.com/albums/v4...e/IMG_3582.jpg It's flared out (increasing frontal area, I know...) because I plan on having the front wheels entirely enclosed. This was the point where at full lock I've got about an inch between the cardboard and the tire. ...and a view from the top: http://img.photobucket.com/albums/v4...0489FF87C6.jpg |
Nice work. But are you going to have enough cooling? There is only a verry little opening.
Well. At least you are actually DOING SOMETHING, versus sitting in front of a computer.
So kudos for that. No disrespect meant, but what did you intend to accomplish with this ? The front of the car already has attached flow, and you could achieve the same results ( if this was done for aerodynamics ) by simply adding a simple grille block. One fella here got great results with an airdam. The car is much like yours. Cars don't need to have pointed ( or even super rounded ) noses until around 300 mph. Aerohead, you out there ? |
All that added length MIGHT be better at the rear of the vehicle ( but you never know what air is going to do )
A good example being MetroMPGs latest boat-tail, or some of the Kammbacks tested here that did nothing. |
How is that birdcage attached to the rest of the car? I'd add a safety wire from the license plate to the car so you don't lose it when the whole thing falls off. Remember what happens when you stick your hand out the open window? Multiply that by the size of your addition.
Did the dents pop out when you climbed down off the hood? Cd -- you can edit a post within five minutes and no-one will know. |
1) to create space so that I can angle the radiator and condenser 60 degrees forward and fully duct both and exhaust through vents in the forward part of the hood. (Obviously I'm not there yet...) 2) widen the front bumper 6in so that I can enclose the front wheels entirely (obviously not there yet either... but I'm closer. :) 3) I had nothing better to do with my time and it was fun Quote:
I honestly don't expect to see any gains from this right now, but it sets up the beginning of what I plan to do for the rest of the car. |
6-8 inches of length on the front is the equivalent of 1in in the rear (or so I'm told.) |
Forget you heard that altogether.
The hood is in proper order. But honestly I wouldn't care if it weren't, I'm replacing the entire front end eventually anyway. |
You disagree? |
Perhaps what W.S. said was awkwardly worded; possibly he meant you could add 6-8" of nosecone and only see the same benefit as 1" of boattail... which is darn near nothing.
You have already seen one of the difficulties of extended noses, that of hitting the ground. Go ahead and test it, but I don't think you're going to like the added frontal area of that cone plus front wheel skirts. There are a few different movable front skirt concepts that don't add to frontal area that I think would have better chances of producing measurable gains. |
http://i835.photobucket.com/albums/z...s/file-519.jpg http://ecomodder.com/forum/showthread.php/military-theme-fun-function-22468-9.html#post325863 |
I am interested to see if there are any benefits to your nose. Your frontal area has not increased by much IMO. The flaring out for the fender skirts stick out like a sore thumb (no pun intended) in the front photo, but this may decrease the drag in that area. TEST IT PLEASE!
I am reminded of basjoos saying that he saw/felt a difference when he put his nose on the Aerocivic. You can't tell until you try. Good work. |
I would not drive with that front end on my car.
Imagine if you hit a raccoon or a person. They would be impaled on the dog cage, not to mention the dirty looks and people taking pictures of it |
Given the mass of the wire mesh, cardboard and duct tape, it would have some negligible value as a crumple zone. But hey, free racoon tail for the radio antenna.
I always imagine a spring-loaded bollard in the traffic lane. Imagination is funny that way. |
However, that being said, I'm 51.5mpg so far on this tank (which is slightly better than my last 3-tank avg), and this has been the only significant change to the car. Still driving pretty much the way I always do. I'm trying to be as impartial as I can. |
Starting to work on the front skirts, I DO NOT like the way this is shaped (yet). Once I get home I'll work on it some more. This was done on the side of the road underneath an overpass.
http://img.photobucket.com/albums/v4...A2A12715FF.jpg http://img.photobucket.com/albums/v4...EEBE9F877B.jpg http://img.photobucket.com/albums/v4...2B207F91B7.jpg http://img.photobucket.com/albums/v4...48F0790D60.jpg |
http://ecomodder.com/forum/showthrea....html#post2112 http://ecomodder.com/forum/showthrea...tml#post322391 |
My head-on with a raccoon Xmas 2012 in an unmodified Toyota Yaris did some several damage to the OEM plastic bumper, A/C evaporator and radiator. Even managed to push the front cross member under the radiator core support back a centimeter or so. No that mock up would not leave much of a raccoon at all.
As a mock up its is interesting. How is the bumper actually supported? My interests is how do you avoid the bumper hitting the windshield or another car behind you if it contacts something in the roadway? Same question with regard to the outboard wheel skirts. Is the final design to be in metal, fiberglass, or carbon fiber? All three will need a support structure, correct? Also why not moved the radiator under the car completely? It might make the nose job more Aero efficient. and could solve some of the cone support issues. With the front extension you will likely need faster spring rates and more aggressive than stock suspension. You don't want a road joist to cause road impact issues. |
pointed
Hucho WOULD say that the nose was already 'optimized' and 'saturated.' basjoos has claimed a benefit on AEROCIVIC. If we consider 'elliptical' section bodies,then maybe there's some 'talking' space.They have very similar drag as a function of fineness ratio.The sticking point is the windshield area.To do glass at these angles means zero outward vision. From Hucho's work on the 1st-gen Golf/Rabbit we can see Prandtl's lines of discontinuity at work.The air is 'avoiding' extreme acceleration,displacing around the nose long before it ever gets there,as if the nose was already 'pointy.' http://i1271.photobucket.com/albums/...titled-6-2.jpg The flow over the 'ideal' nose is no better,and drag no lower http://i1271.photobucket.com/albums/...titled-7-2.jpg ------------------------------------------------------------------------- Some land speed record cars have 'pointy' noses,but they're in transonic,compressible flow,where shockwave drag must be addressed. GM's Firebird I http://i1271.photobucket.com/albums/...titled10_1.jpg has no lower drag than today's FIAT Cinquento http://i1271.photobucket.com/albums/...titled16_4.jpg |
Aerohead - you must get tired of having to repeat yourself a lot huh? ;)
Yikes!
Yeah, the more I think about all of this, the more I don't like the idea of increasing frontal area at all. It just doesn't make too much sense. On a positive note, more people are asking me what kind of mpg I get instead of asking me what's wrong with the car. :) |
I especially like the idea of gaining space to duct air to the radiator.
So, very long story short, the previously pictured version of the front was destroyed. So, I remade it. Better this time.
Materials are corrugated plastic (instead of cardboard and duct tape) and the frame is made from aluminum and some other light weight metal. This time it took me about 8hrs, but I also had to make a new fender liner on the right side. (The previous one was ripped off in a snow storm) http://img.photobucket.com/albums/v4...e/IMG_3683.jpg http://img.photobucket.com/albums/v4...e/IMG_3684.jpg http://img.photobucket.com/albums/v4...e/IMG_3685.jpg http://img.photobucket.com/albums/v4...431F6AE876.jpg http://img.photobucket.com/albums/v4...4EAAC21723.jpg http://img.photobucket.com/albums/v4...DCAC579655.jpg http://img.photobucket.com/albums/v4...443099FED4.jpg http://img.photobucket.com/albums/v4...94A54580CC.jpg http://img.photobucket.com/albums/v4...2599BFDC7B.jpg And the current state of it: http://img.photobucket.com/albums/v4...77DBCF0234.jpg There is still more to do, but I'm happy with it so far. AND, it certainly isn't hurting anything... This is my current tank so far (about halfway through). http://img.photobucket.com/albums/v4...57D8E80F1E.jpg |
Nice work. Bummer about your driveway angle.
pictures don't do that car justice looks great in person.
I'm starting my work on the rear of the car (again) hopefully next week, and the lower diffuser angle WILL be determined by my driveway. It will probably be a steeper angle than the template shows, we'll see. |
Not bad for coroplast. You've got a lot of twisting surfaces there to contend with! I think if you ever wanted to sculpt a "permanent" version in fiberglass it would look pretty cool.
I kind of like the graphics of the campaign sign better than the painted version though. :D |
This is very cool. I like it. I'm jealous .
I would put the bumper core metal support back in. They do more in a crash then you think. |
http://img.photobucket.com/albums/v4...e/IMG_7941.jpg So when I removed the metal bumper, I could not re-attach it. I've also tried to re-attach a new (not damaged) one and could not. In order to do all of that I'll need a body shop to do some work for me. I am aware of the risks to the car (and therefore myself) by not having that added protection there. |
A couple of other photos...
http://img.photobucket.com/albums/v4...5D0B1B5024.jpg http://img.photobucket.com/albums/v4...64DCA9ACDE.jpg |
Is that a qrcode in your window?
It is :)
Love the nose Zach! And Dave is right, it looks outstanding in person. It also has helped his mpgs, since he did get 67 going to the state park yesterday for our meet! |
