EcoModder.com
-   -   The 'Vic - 96 Civic DX (https://ecomodder.com/forum/showthread.php/vic-96-civic-dx-21263.html)
hawk2100n 04-01-2012 10:57 PM
Here is the build thread for my 96 Civic DX 5 speed. I bought this car on February 15th 2012 as a replacement for my 06 BMW that I had decided to sell. I wanted something cheaper and more fuel efficient. It was basically an experiment to see if I could drive something a little more economical all around. I have fallen in love with this little car and have spent most of my time repairing and restoring the vehicle.
The major work I have done so far:
Thorough cleaning
Fixed jammed parking brake
New wiper stalk
New spark plugs and wires
New timing belt, idler and water pump
Painted
New tires
New air filter
Full size spare tire
New O2 sensor and modified secondary O2 sensor with spark plug non-foulers to fix CEL because previous owner had a headers to replace a rusted catalytic converter.
Since I have fixed almost everything wrong with the car, it's time for me to start efficiency mods.
The first thing I did was make an upper grille block from some black plastic I picked up from Lowes. I ran it for a little while but my consumption fell within the range of normal fill-ups so the results are inconclusive.
http://i.imgur.com/kHWWX.jpg
The next thing I did was I bought a Scan Gauge. The fist tank I ran with it was 44.5 mpg, and this was running about 50% of the miles with AC. My average before this was 37 mpg and ranged between 35 and 39. My high was 40.5 before this. The Scan Gauge works well and the setup I have on it is:
MPG________TPS
AVG________RPM (DX doesnt have a tach)
I will say that I am more experienced at utilizing instant and average MPG information because the car I just sold was my third BMW and they have all had analog MPG gauges. I consistently exceeded EPA figures in those cars over about 100,000 miles in all of them combined but it wasn't a goal like it is in the Civic. I am excited to continue refining my driving skills and am glad to see RPM and TPS info. The TPS value is good to know and helps me more than I expected.
California98Civic 04-02-2012 12:15 AM
I love the new paint job. Black like mine! Does the scan gauge have an engine load % readout? If it does, you could replace TPS with it and accelerate with load between 75-80%, shifting gears at 2000-2200 RPMs. That's roughly the figures I learned for our DXs by imitating Palemelanesian, who scores some of the very highest MPG on this site through nothing but some serious driving discipline. As soon as I followed this formula, my number increased.
Also, delete your power steering, if your DX original owner bought it as an option. You won't notice a difference at any time except parallel parking. It will save fuel.
I just reinstalled my black lawn edging chin spoiler under the bumper... I trimmed the top lip off the edging to get down to about 3" and still have the second lip to use for attaching the edging to the underside of the front bumper.
I'm am glad you love the car. I have driven mine for 11 years and still love it.
Oh yeah! I posted a link on this site for a free copy of the 1996-1998 Civic official Honda Service Manual. Search this site and it'll come up.
james
Thorough cleaning
New wiper stalk
Painted
New tires
New air filter
MPG________TPS
IsaacMTSU 04-02-2012 12:10 PM
Nice! The paint job looks good
hawk2100n 04-02-2012 04:00 PM
james
I snagged a copy of the manual you posted a couple of weeks back. And I might take off the power steering. I will just remove the belt at first and see how it goes. I agree that the effort isn't bad because I have been dabbling with EOC here and there. Some of my friends have noticed and asked why my car is so quiet when I pull into the parking lot.
PaleMelanesian 04-02-2012 05:53 PM
Nice car! I concur about using LOD instead of TPS. I like mid-80's LOD for pulsing. These cars respond VERY well to Pulse & Glide.
I found the Scangauge to read a little high on MPG. I have a 13% offset on mine. (in the fillup process)
hawk2100n 04-02-2012 08:13 PM
Thanks for the tips. I played with it a little this morning on an 80 mile drive. My scan gauge is all sorts of mis-calibrated. I forgot to keep the setup instructions in the car and botched the first fillup calibration by making adjustments. I guess that means that the indicated 58 mpg/80 mile run wasn't correct this morning. And I think that my reports may have been too soon, as I topped off my tank today again and reset the scan gauge but it drank 2.8 gal for 30 mpg. So I suspect a short-fill skewed my numbers. I have 1000 miles of driving this weekend so it will be settled then.
hawk2100n 04-06-2012 12:30 AM
So your scangauge routinely indicates that you get 79 mpg average? wow
I switch to LOD and I like it. The 80% range actually gives me better acceleration than I had been (driving, doing, making, having, odd verbiage) before.
I removed the power steering belt today as an experiment to see if the car is livable. I don't have a problem with it at the moment. My driving has been unusually limited this week compared to normal (averaging 124.5 miles per day) and my scangauge readings will not be trusted until an accurate fill. Right now the TANK AVG is 46.5 mpg.
Pale, what is the off event for your scangauge? 0 RPM? I changed mine to COM hoping that I could keep it alive during EOC but I am switching with the key so the computer still shuts off with the engine at first until I switch it back. Any workarounds for this? Fuel cutoff switch I suppose is the best solution to kill the engine.
PaleMelanesian 04-09-2012 09:12 AM
Change fuel type to Hybrid and it'll stay alive as long as it's powered up. That's all hybrid mode does. Com is still default.
If you look at my log, it was a couple years of full-time hypermiling before I got to this level. Practice makes perfect (or at least better ;)).
hawk2100n 05-02-2012 10:34 PM
Civic update: I realized that I haven't ever quantified my gains from my two minor ecomods. Grille block and a power steering delete. The power steering was only the removal of the belt but the entire system is still there with the belt and a wrench in the trunk. But with a 4376 mile baseline and 2781 miles with mods I can be confident in the results.
Before: 37.24 mpg
Modded: 41.07 mpg
Difference: 3.83 mpg / 10.3% improvement!
I am very happy with these results! Are my real world driving results acceptable to substantiate my claims? I don't want to do ABBABAB testing.
PaleMelanesian 05-03-2012 09:59 AM
I think there's too much real-world variation to claim anything for sure. I don't doubt the mods helped, but you need ABA all-else-equal testing to know how much. Temperature, rain, wind, routes, traffic, your mood, your driving style... each of these can be a 10% difference or more.
