Old 01-08-2024, 01:16 AM   #1 (permalink)
3D printer
I want to DIY a 3D printer. I bought a stepper motor online, skysmotor.co.uk but I don’t know what else I need to prepare?
Old 01-08-2024, 02:31 AM   #2 (permalink)
https://duckduckgo.com/?q=DIY+3D+pri...ruction&ia=web
https://www.youtube.com › watch?v=qub5chyIQ0s
How to Build a 3D Printer (The Ultimate Guide) - YouTube
23K 2.9M views 3 years ago Dr. D-Flo's Web 3D Printer Guide: https://dflo.info/3D-Printer-Building 3D Printer Components from OpenBuilds (Paid Link): https://geni.us/OpenBuilds Dr....
https://3dprinting.com › 3dprinters › building-a-3d-printer-from-scratch-tips-tricks
Building a 3D Printer from Scratch - 3DPrinting.com
There are 4 different main types: Mendel / Prusa, Darwin / Ultimaker, Corexy and H-bot. I have built a Mendel / Prusa style printer and a Darwin / Ultimaker style printer. For the purpose of this article, I'll go into full detail of building these two types, and explain the basic details of these other types.
https://3dinsider.com › how-to-build-a-3d-printer
How to Build a 3D Printer: Parts list and Basic Steps - 3D Insider
The costs and time required to build a 3D printer depend on your starting point as the process can mean two things. It can mean assembling a DIY 3D printer kit or building a 3D printer using individually sourced parts. With the former path, you assemble a 3D printer from a kit that contains everything you need, including spare parts and some tools.
https://www.youtube.com › watch?v=EX62plOF-So
DIY 3D Printer Build Your Own - Part 1 The Frame (Step By ... - YouTube
4.1K 266K views 4 years ago DIY 3D Printer Build for Beginners - LayerFused C201 (Open Source Design and under $200) Day 1 of our Build Your Own DIY 3D Printer. Follow along each...
https://www.instructables.com › DIY-3D-Printer-From-Scratch
DIY 3D Printer From Scratch : 8 Steps (with Pictures) - Instructables
Step 1: Building the Frame The frame is a very straightforward process. You simply need to screw everything together. Some tips when doing the assembly is to make sure things are square and level. Since a 3D printer is a precision tool you need to make sure you tighten everything well. View the DIY
Two more stepper motors, belts or screws, a frame, software...
Old 01-09-2024, 10:28 AM   #3 (permalink)
Motor controller, io interface.......Laptop or equivalent
While back there were kit makers selling DIY kits of the eccentric bits for $100 USD and basically lacking the structure
