Old 04-13-2010, 04:51 PM   #1 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Angry 04 Prius Slvg/Lost In Texas
Does anyone know what the OBD code P0A80 and P1150 mean??
These came from a 04 Prius Hybrid
Old 04-13-2010, 04:54 PM   #2 (permalink)
P1150 - Air/Fuel Sensor Circuit Range/Performance. (Bank 1 Sensor 2)
Dunno about the PA code.
The Following User Says Thank You to Daox For This Useful Post:
TexasCotton (04-13-2010)
Old 04-13-2010, 05:00 PM   #3 (permalink)
sorry my bad.The code is P0A08 I think it means my ICU is shot!!
Old 04-13-2010, 05:07 PM   #4 (permalink)
P0A80 - The difference in voltage between 2 of the blocks in the battery pack is too high
Old 04-13-2010, 05:27 PM   #5 (permalink)
Please define "blocks".? If the trac battery is not discharge/charge correctly in a group of cells.?
Old 04-13-2010, 06:33 PM   #6 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Isn't a block every 12 cells? I remember something about the system being broken into ~14+V segments for measurement.
The Following User Says Thank You to roflwaffle For This Useful Post:
TexasCotton (04-14-2010)
Old 04-13-2010, 08:52 PM   #7 (permalink)
I'm not sure what a block is. The guys on priuschat.com might be more helpful with this specific info.
Old 04-14-2010, 05:04 PM   #8 (permalink)
Cool 1150
Okay I borrow a Haynes Prius Repair Manual based upon a limited "teardown" and "rebuild". The OBD codes listed in the manual are about 4-5 pages because they cover model year 2001-2008 kinda dumb since Gen 1 Prius has significant difference from Gen 2. Anywho according Haynes 1150 code is coolant blockage. The other code is not printed in Haynes. However Toyota service writer related to Hybrid control system.
Check out this link about codes http://www.eaa-phev.org/wiki/Prius_PHEV_TechInfo
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
DIY Salvage 04 Prius/Lost in Texas (seeking repair advice) TexasCotton Hybrids 11 05-09-2010 02:13 PM
Prius fatal accident rate bwilson4web Hybrids 22 02-05-2010 11:23 PM
'04 5.3L Chevy 1500, 2008 Prius, and motorcycles Trojan00 Introductions 0 09-12-2009 07:52 AM
Hybrids- A DANGER to the environment! Hermie Hybrids 35 09-10-2009 03:04 PM
