Visualizing Air Flow: here's an idea
1 Attachment(s)
1. Have you ever played with spinning fiery steel wool as a kid ? I know I have.
2. Have you ever experimented with long exposure photography ? I know I have. 3. Are you looking for a way to visualize air flow on your vehicle, for an in-depth understanding of its interactions with said-object ? I know I am. How about combining all of those ? Imagine installing a spinning device on the lower front bumper, near the stagnation point, and lighting up some steel wool. The resulting fiery fine steel particles would cover the entire frontal area of the vehicle. The incoming air flow would then re-align those particles from a sideways momentum to a longitudinal momentum, thus creating lines of "visible" airflow by using long-exposure photography. The same could be done at the rear bumper in order to expose the wake turbulence.
The spinning device could be cordless drill. Been thinking about this for a while. Wondering if it might work...:D Thoughts ? https://ecomodder.com/forum/attachme...3&d=1676149754 |
Back when we were talking about smoke trails, aerohead told the story about when he lit off a green smoke grenade on his surf board and an attack helicopter came sniffing around.
My suggestion at the time was something like a windshield wiper that would sweep the entire frontal area with a nozzle that would travel along it's length. Substitute Dragon's Breath rounds. :thumbup: Quote:
So if I undersand, this produces smoke, correct ?
Or is more like sparks of some sort that emanate from it ? I like that idea of time exposure photography ! |
https://farm7.static.flickr.com/6183...5460d717_z.jpg It would be a like a CFD, but in real life. :eek: |
But what will the hot sparks do to the surface of the car?
Odds are it would probably cause some damage. Tests would need to be undertaken on a variety of surfaces, prior to attempting it on an actual vehicle. :thumbup: |
I wonder if most of the particles would just flow downstream with the laminar flow, without much contact with the surface paint.
Side mirrors and the front bumper are another story, given that they would be obvious obstacles where the heated particles would do the most damage. |
A picture I've always wanted to find was in an ad in Hot VWs in the 70s or 80s. VW Beetles racing in the rain with rooster-tails of water off the top of the windshields.
Things heavier than air don't act like air. |
5 Attachment(s)
BTW, I found out that youtube automatically makes these videos " Youtube Shorts ", so I'm not sure if you all can watch the video in slow motion and zoom in. Anyway, here is a still frame from the few seconds of video I posted. I definately shows how that indeed rain spray is not a good indicator of drag. Just look at how some small cars kick up more spray than trucks with open trailers !NOTE - I really zoomed in and cropped these images : https://ecomodder.com/forum/attachme...1&d=1676235861 https://ecomodder.com/forum/attachme...1&d=1676236883 https://ecomodder.com/forum/attachme...1&d=1676236883 https://ecomodder.com/forum/attachme...1&d=1676236883 https://ecomodder.com/forum/attachme...1&d=1676237055 |
