Voltage fluctuation problem !
Hello,
Newbie in the fabulous world of eccomoder, and MPGuino, I would like to ask some help. Last Week I bought a MPGuino for my 1998' Fiat Punto 55s 1.1L SPI. I install it. But there is a problem: On each display , speed, L/KM , Volt , there is a significant variation in the values displayed (~+10% - 10% every ~5s) . Then I try to only read the Voltage (engine and ignition Off) and there is still a lot of fluctuation. The second problem is that the L/H is only shown in idle. If I accelerate very slowly , the value increases normally (but with the same fluctuations) , but at midrange , it reboot . If I accelerated faster (usually done while driving ) , the screen freezes , and I need to unplug and plug again to reactivate I have some video on youtube to explain that, but, as a newbie, i'm not able to show it to you !!! Sorry for my bad english writing ! and thank you... |
What code version of MPGuino are you using? |
Hello,
Version is 0.97m here is the part of the link : watch?v=UE6MxPAy03M watch?v=YhhscWJ7Lts I don't understand why every 5 seconds, the value (Speed, L/H, or whatelse) is going up, then down, the stable....). It is the same with the voltage only (engine and ignition off). Other issue is the fuel flow freeze and reboot !! |
[youtube]UE6MxPAy03M[/youtube]
[youtube]YhhscWJ7Lts[/youtube] This appears to be a meelis11 MPGuino. You should PM him - he is a member here. It's possible you have a defective unit, especially as your voltage value keeps moving around, while your multimeter voltage remains steady. Edit: You might also want to check your electrical connector. |
Hello, and thank you for your help.
Yes, it is Meelis the seller. I contacted him, he suggest to solder contact to avoid the reboot. It seems unusual to have regular fluctuations (every 4 ~ 5 sec) on all values at the same time. no ? Other owners can tell me if they have these fluctuations, or I'm the only one. On other MPGuino youtube video, I see that the values are stable. Also, what is a "normal"percentage of the CPU ? With only the +12 v and ground connected, I'm 77%? Is this normal ? Thank you |
