Vortex generators in diffusers
Hi, has anyone tried the Vortex generators or airtabs as if they were a diffuser?
In theory, they should push the air upwards, enhancing the effect of the diffuser, not? |
Yes, but...
Maybe not what you were asking for, but something said reminded me of this image below from page-2 of the link.
Most interesting car aerodynamically - 2016 https://ecomodder.com/forum/showthre...6-a-34854.html http://www.mulsannescorner.com/AudiR...st2016-SC3.JPG Original source: Mulsanne's Corner: Race Car Engineering Le Mans 2016 http://www.mulsannescorner.com/Kolle...ce2016-SC1.JPG http://www.mulsannescorner.com/Toyot...ne2016-SC1.JPG |
Might as well out myself...that site looks familiar :) |
Has anyone tried something like this?
https://www.sigmaautomotive.com/perf...kz/image12.jpg Site: sigmaautomotive |
No, I have not seen that done before. Is there any point to putting those at the very end when there is nothing to reattach to? There is just a wake behind the car. And in this white car's situation, not even a plane before it, just some very confused air. From the clip flanges there seems to be a belly pan piece missing. |
I think it can improve because it can make the air move up where there is less pressure and thus gain more downforce. And reduce wake area.
The same happens with the airtabs installed on the sides of the trailers. And how race cars have diffusers, they should not need this. |
vs Those aren't vortex generators, those are (wimpy) fences. |
But, I have several questions: 1) Does generating a vortex or several vortices there mean they'll migrate upward, against gravity? 2) What effect or interaction will that vortex/those vortices have on the large vortices formed naturally and shed by the car's C-pillar? 3) How many times can one say "vortices" before it starts to sound weird? |
It's hard to tell from that angle but it looks like the two sides are set at a slight angle. Just not enough— compare to the V-shaped Airtabs.
I don't think anything can act at right angles to the airflow. Any effect will propagate downstream. If you want to wrap air around an edge, you need the Coanda effect. https://ecomodder.com/forum/member-f...70-imagesa.jpg Else, cold plasma actuators. Both require energy. |
Copyright ©2000 - 2019, vBulletin Solutions Inc.
