Vortex generators - where's the solid data for hatchback/van benefits?
Info given to me by Ron Davidson at Airtabs. (Posted with permission)
http://images6.theimagehosting.com/a...vic-two.th.gif http://images6.theimagehosting.com/a...c-three.th.gif |
The Australian AutoSpeed web site recently ran a 4-part series on VG's. Some of the articles are open access, some require payment:
http://www.autospeed.com/cms/search/...vortex&x=0&y=0 The writers have done quite a few excellent articles on DIY aero mods before, and they're normally pretty rational and scientific in their approach (ie. decent methodology, healthy skepticism). I've paid the $5 to access a few of their articles in the past, and haven't been disappointed. They claimed they "tested" VGs on the rear of an Insight and a 1st generation Prius in the last instalment of the 4-part series, so I bought access to one of the articles to read the results. Save your money: there were no "results" because they didn't properly test them! They did show a beneficial improvement in airflow down the rear window of the Prius via photographs of tuft tests, but they didn't quantify the results re fuel consumption changes. http://us1.webpublications.com.au/st...0/3061_5lo.jpg http://us1.webpublications.com.au/st...0/3061_3lo.jpg For the Insight, they didn't even attempt to do controlled back-to-back testing - they just drove their regular commute over several weeks and then compared the results there to (apparently) a single commute with the VGs attached. That methodology sucks! And it doubly sucks because this is the application I'm most interested in: ie do VG's have the ability to reduce wake / base pressure beyond the trailing edge of a hatchback-style vehicle? http://us1.webpublications.com.au/st...0/3061_8lo.jpg Still, they somehow feel confident enough to conclude that: Quote: Quote:
I've had a box of airtabs for quite some time, but I refuse to just stick them on the car and pretend they work.
I've prepared to do a test: attached the airtabs on flexible/removable plastic sheets that I can remove in a jiffy at the road side. I just need to make another couple of sheets to complete the sides, and double-check with the distributor that the placement is OK. click/zoom... http://images6.theimagehosting.com/s...-orange.th.jpg Above: I increased the spacing between the tabs by 50% to compensate for the 45 degree angle on the rear window. I may not be able to place an uninterrupted line of them down the side of the car due to contours that they won't stick to. But I'll add a few more at least. http://images6.theimagehosting.com/3-4.5c5.th.jpg Unfortunately, I've been too busy to actually DO the test yet. |
VG freeway stats
2 Attachment(s)
At last a site for milage OCD!
I drove from Vancouver to San Antonio and back in a 1995 VW Eurovan camper at the local posted speed limit. Gas auto otherwise unmodified typical 16 mpg. I would remove/install these VG's at fill ups and check mileage per tank. Considering the cost (2 yogurt containers & a meter of white electrical tape) the approx. 7% mileage increase (~$50 saved - $85 if I'd had them on the whole trip) was acceptable. Definitely a TLAR installation. Would be nice to do wind tunnel/tuft/rainy day video testing to optimize location. A similar installation on a VERY heavy U-Haul trailer showed a 2% improvement. |
That said... back to your anecdotal info... I'd be interested to hear more details about your experience with the things on your van & the trailer - E.G. how many on vs. off comparisons you made; whether the weather, road conditions & terrain were similar from tank to tank. There's no shortage of customers claiming great things about airtabs in the company testimonials. But you have to take that with such a huge grain of salt, it's not really worth very much. Again, not saying they don't work. But I would like to see some more convincing data for my application. Either that or I need more warm months in the year to gather the info myself. |
randomization
Considering that during this 15,000 km test the combined vehicle weight was 2500 to 5500 kg, speed limits vary from 45 to 130 km/h, altitudes from sea level to 10,000 ft and a prevailing westerly wind I just alternated on/off at each tank ~500 km. This then gave me, say, 500 km on and 500 km off at the Colorado Plateau, same at 80 mph Texas freeway speeds. Once I had convincing data I just left them on for the last 3000 km or so, since by then I was driving in heavy snow & mountain passes which gets a bit too variable.
TLAR: That Looks About Right :D . These are about the size & angle of attack of aircraft VG's (400 km/h) at half spacing, installed at about the location AirTabs recommends. I didn't do the reynold's number conversion to see if the size was appropriate. I will bet double density would help. Since then I also have tried premium gasoline which gives an 18% improvement (!) for a 10% cost increase. This is city driving and probably type-specific. Per tank mileage variability was 9 to 25 l/100 km so the Signal to Noise Ratio here is pretty crappy. The fuel flow meter in the Saskatchewan Metro Videos would have speeded this up considerably. |
I'd say if you don't have a sizeable 20-45 degree slope towards the center of the vehicle in the area after you place the air tabs, you'd be just as well off writing a check out to me as buying air tabs. But don't worry, I won't rip you off, you'll be getting the most premium magic beans sourced at great expense from exotic locations around the world.
I have some pictures, somewhere, of my buddy's rowing oars... He got them recently and have vortex generators on them (on leading edge)... I believe his immidiate comment on the first stroke was something like "These new oars are F'ing sweet" or something like that :p
The Mitsu Evo has similar fins on it.
http://www.scoobyblog.com/wp-content...006/10/011.jpg http://www.onemotoring.com.sg/publis...0005.Image.gif |
