vristang
My name is Jason and I have a 1987 n/a 2.3 Mustang LX with a manual 5spd.
Currently getting around 26mpg, but starting to get the tune dialed in. Some things I've changed from stock... Ranger roller cam Ranger header ranger dual plug head & intake EDIS conversion using a 1993 Lincoln MkVIII computer Wideband O2 Moates Quarterhorse Currently the CR is around 9.66:1 The computer change was pretty recent and I still have a lot to do with the tuning. It should be in the 30-35 range when it's dialed in. I drive it 115 miles/day. jason |
Look a my mileage on my 1997 Ranger. Mine has the Mazda transmission with a .79 overdrive 5th gear and a 3.45 differental. Works out to about 2200 RPM at 60 MPH. I have an aero cap, smooth wheel covers and a total upper grille block, with Bridgestone Ecopia tires. Best tank so far was over 33 MPG. Last tank was 31.5 in winter temps here (about 40-50 average).
regards Mech |
pump up the tires!
oh and welcome! |
Welcome to the forum.
You'll have to edumacate me on "vristang" though! |
I'm known on several Mustang/Ford boards by that name now, so I'm kinda stuck with it... |
Welcome aboard. Please start a fuel log so we can see your progress.
