vw jetta wagon (can I install MPG gauge from V6 model in 1.8T model?)
I have a 2003 vw jetta wagon with the 1.8l turbo engine. I would like to put a mileage meeter on it that came from another model of the same car, the 6 cylinder version does anyone know if this is possible?
Where exactly is the mileage meter located? If it's in the cluster it might be as simple as a cluster swap, if you don't need to change any other electronics, but perhaps that's not it.
You could always pick up a scangauge, not stock but will give you more information with perhaps more ease. Welcome to ecomodder :thumbup: |
I mileage meter is in the instrement cluster. I found some swap info on the vwvortex forum. thanks I am planning on a scanguage
Good stuff. When I drove the 09 jetta tdi I was pretty happy with the cluster mpg readout, just wish it would show more than one piece of data at a time.
Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community |
module 17 19 re coding to match immobilizer
it is possible
BUT the immobilizer coding will not match module 17 and module 19 are both located in the cluster AND they must be coded to the car or nothing in the car will function and the car will not start that info will be available in VW Vortex also see RossTech regarding immobilizer you will need to bring it to a shop that has OEM VW coding capability or a VW Audi dealer VCDS will not do it on a 2003 Quote:
