EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   VW New Beetle Mirror Delete (https://ecomodder.com/forum/showthread.php/vw-new-beetle-mirror-delete-17111.html)
SwamiSalami 04-29-2011 08:00 PM
Help! Can anyone help me find a step-by-step on the process of removing my new beetle's side mirrors?
Sincerely,
dieselbeetle
SwamiSalami 04-30-2011 03:00 PM
I guess I'm on my own on this one!
euromodder 04-30-2011 04:57 PM
This is how weatherspotter did it :
HOW TO Page - EcoModder
Make sure you seal the cover well on the outside !
If not, you'll get water in the door.
SwamiSalami 04-30-2011 05:23 PM
wow, awesome.
I wonder how similar a beetle's side mirror is?
ChrstphrR 04-30-2011 08:59 PM
If I were you, I'd check on TDIclub for beetle specific howto's ... And barring that, VWvortex.
If not the same as a Golf/Jetta, it would at least be *similar* enough that you'd have a good idea what remove to get it off of your door.
smck 05-01-2011 05:16 PM
1 Attachment(s)
I don't know if it's the same or not but when I did the Golf I just had to remove the door panel and then take out a few bolts for the mirror assy. I can scan the page out of the Bentley manual if you think it will help.
The attached picture is how mine ended up looking. Made a template from paperboard then transferred to a cheap rubber mud flap I bought at the auto parts store. Sealed it up with black silicone rtv.
hardwired 05-06-2011 04:42 PM
The problem with the new beetle is the mirrors sit on top of the door hinge and it sticks out a few inches to compensate for the body lines, I've thought about using smaller mirrors that would mount back of the hinge but then the mirror would have to swing out with the door. modeling a small cone infront of the hinge with a moving mirror is something i haven't started to wrap my head around.
SwamiSalami 05-07-2011 02:04 PM
I would LOVE it if you uploaded the bentley manual page!
Thanks
SwamiSalami 05-07-2011 02:07 PM
Interesting.
hardwired 05-09-2011 10:26 PM
1 Attachment(s)
sorry the current mirror does move with the door, maybe hard to see in the picture the mirror mounts just below 3
