VW quantifies MPG gain of 4- to 2-cylinder deactivation at 31 mph = +16 mpg
For those of you (and there have been a few) who have dreamed of and/or actually tried your hand at DIY cylinder deactivation (mechanically), VW has provided data on the fuel economy improvement achieved by switching from 4 to 2 cylinders at various speeds in their 1.4 L gasoline engine which will be in this year's "Polo Blue GT" model:
Driving at a constant speed (load): (Note baseline mpg for putting these figures in perspective: the car is rated either 50 or 52 mpg on the Euro cycle depending on transmission choice.)
The article doesn't say how VW accomplishes deactivation, but presumably it's by shutting both the intake & exhaust valves on the cylinders. EDIT: found a video demonstrating VW's approach... www.youtube.com/watch?v=yxjGTBF-dVY EDIT 2: here's VW's press release (edited to remove some unrelated topics & shameless marketing-speak): Quote:
IMHO it would be more effective to disable the appropriate injector and leave the valves alone, it seems to me that by shutting both intake and exhaust valves the piston would essentially be creating a vacuum causing even more issues.
Leaving both valves open would pump oxygen into the exhaust stream and mess with O2 sensor.
I think just leaving intake valves open would work better, if they deativated the same 2 cylinders all the time and the pistons are 180 off each other I wonder about connecting the intake runners between them to push the air back and forth between the 2 cylinders. |
wd, rooster: there are articles here and online explaining cylinder deactivation. Would the manufacturers close off both valves if closing one or none worked better? Really? You are missing a major part of the whole theory and that is reduction in pumping losses. Think about why air compressors require so much power.
I've played with this at home and was hoping someday they'd get it to work on a 4 cylinder. Mine sounded like it wanted to start but it just couldn't quite do it. Of course one of the key things might be to start on 4 then switch off at higher rpm as there just isn't quite enough inertia to get 'er going on 2, but I had to try starting on 2 because my deac scheme was under the hood, not on the go. Thanks for the figures metro; some rough extrapolating says maybe +15% could be expected on average... that's about what DoD for larger engines gets too... so for the Tempo I'd be looking at +5 or 6 mpg. Nice, but perhaps I won't be pulling those two pistons after all. :/ |
Frank: maybe you needed another battery inline on the starter circuit, so you could have spun the engine up to a higher RPM with the key. :)
Ha- it was spinning over pretty good. Gee I wish I had a 48 volt system! errrrrr.... Next time I'll get Cletus to gimme a tow up to 55 mph or so and then see if it starts/stays running.
We all know that 2 cylinder engines start, run, and work. I think if mine had more flywheel it would have gone. Or, if it had a 2 piston delete. Or an active deac system for high rpm deac. rooster: I haven't seen it mentioned (or, I forgot :rolleyes: ) about if the timing of the valve closing event is critical. I would think that since piston rings don't make a PERFECT seal, that cylinder pressure- or vacuum as the case may be- would reach some sort of equilibrium in short order. After all that piston will have gone up and down thousands of times in the space of one minute... |
Rush fixit job just before the welding supply store closed. Made it to the store, then hooked everything up to get home on four cylinders. |
Mine'll run on two if I just pull the spark plug or injector wires, but I went the distance and disabled the valves.
for a 1500 cc engine, that is 15 percent or so.
which is EXACTLY the math we came up with in the bsfc thread. pretty amazing stuff, because the math suggests it is 15 percent for ANY gasoline engine. |
