VW start stop hack
I am planning on purchasing a vw passat. I already have a passat that i bought for my mom (2010 1.8 TSI, 6.3L/100km my current average).
It has a dsg and i am fairly happy eith it except when parked on steep hills where it sucks. For my purchase dsg will not be a deciding factor unless the start stop feature can be hacked on the manual transmission so i can do engine off coasting. I searched the forum but was unable to find anything. Has this been done before? Tjese cars do not really have a key anymore so it is not possible to switch the engine off :( |
For a normal petrol engine you'll be able to do the usual kill switch and bump start, but you'll also have to switch off stop/start at the same time.
P&G with EOC is for NA engines with low gearing. In a high geared turbo there's little point to it, and in some cars, it's actually worse. I know the 1.2TSI shows around 0.4l/hr at idle (the 1.8 a bit higher obviously), so it's really not worth the effort of a kill switch, just use neutral coast. |
The 1.8 tsi consumes 0.8-1.2 l/h while idling.
I was thinking of getting the 1.6 tdi manual. |
Would coasting down to stop lights etc be beneficial with the engine cut off in advance.
Just curious if it can be hacked, it should already have start stop. |
If you simply kill the engine, stop start will try to restart it - if you run out of fuel for example, the engine will just keep cranking.
On a TDI I don't think you'll be able to kill the engine without a mass of warning lights and logged fault codes. |
I wonder if the ecu can be hacked for this.
Save the stop function activate at sat 30 kph while coasting down to a stoplight
Diesels have so little engine braking that you may as well just DFCO to a stop. P&G is a thing for throttled engines, not diesels any way. You'll see better numbers just keeping in 'lean burn' than using P&G. |
Seems like a viable project to me. I'm a bit of a noob to car-hacking using computers but here is a good list of tools that I found so far:
- Car Hacking 101: Tools of the Trade | Make: The Stop/Start system would be interesting to have even on non-vw cars. So whatever algorithm you came up with for that could be a generic template for other cars. To me, I would pick gps based start-stop. Because many logic-assumptions would be based on things like distance to the next traffic lights and current speed, are you going up a known incline or down. Yes, the Honda Jazz/Fit has that type of sensor in its gearbox already to read incline but what fun is that - especially if that is not your car. I'm swaying to using a Raspberry-Pi for all this because of the higher-level software tools. Using pieces from the above link you could actually start implementing some of this soon. Quote:
You can colour mask it to find out if it's green or red. |
