Vx d15 questions (VX vs DX trans)
I am wondering what the fuel economy difference is between the taller 5th gear VX transmission compared to the 5 speed from a DX? I found a Civic with a D15z1 in it, but I'm pretty sure it is still the DX transmission, and wondering how much it is leaving on the table, fuel economy wise.
Is there anything else to consider about a swapped Z1, I'm guessing the ecu has to be from the z1, anything else? Thanks in advance. |
Also, could you guys confirm that this is a D15Z1? I have always told them apart by the oil cap on the top corner, the spark plug location, and the valve cover. So to me this seems to fit, but I want to be sure, and I have asked the seller about engine code, but waiting to here back.
... And yes I would probably switch the header to a manifold if I were to buy this. Edit: maybe I should add the pic, http://i282.photobucket.com/albums/k...G_00000176.jpg |
Also the D15z1 had egr with a control box but I would not bother with it unless you need it for emissions. |
Oh wow that much?! Do you think it could pass emissions without the egr control box? How much of a hassle (and money) is it? Would not having egr hurt its fuel economy?
He said that it is a "d15 mini-me" swap. I am totally new to hondas, and im searching but having a tough time understanding this mini me swap. So it is not a d15z1? It is the engine pictured above.
Edit: it appears this is probably a d16y8 head.... |
Well this to me sounds like I'm going to pass on it... I will keep searching and waiting for a decent vx to pop up. Someday I will find one..
My stock VX would do 30 MPH at 1000 RPM in 5th gear, same as 90 MPH at 3k RPM in 5th.
regards Mech |
Wow that is a seriously deep gear. That to me says to avoid this car as well, too many things I want to change, work on, improve, etc.
Mini me is a 6z head on a d15 block. It's a speedy setup, not terribly efficient. That car would only get 32-35 mpg mixed.
