Want low drag? Don't follow a template.
I see Aerohead, completely undaunted, is back to spreading his misconceptions about his beloved template. Here's video I did on that subject a month or so ago.
(If you wish to comment, please watch the entire video, including the citing of five completely differently shaped low-drag templates.) https://www.youtube.com/watch?v=hxmbQhcNWy8 Using Aerohead's template as the guide in aerodynamic car modification and assessment is, unfortunately, quite absurd. If only it were that simple! |
Not again!
I enjoyed the video, thank you for posting it.
For reference a post of mine from 2017 questioning some of the same things. You need to click the link to read the whole post including charts from a another forum reference. https://ecomodder.com/forum/showthre...s-34840-4.html Quote:
Perhaps the very slight imperfection of a physical medium that has mass/weight and surface area (the yarn tuft) has not been overwhelmed by the ever so slight pressure differences. It is their own weight that is holding them down (gravity) and not air pressure or air flow? In a 1930's NCAC video posted earlier this month the demonstrator using a small wind tunnel used a wand with what looked like long stringy bird feathers much lighter and delicate than a yarn tuft, and this allowed him to actually show vortex formation around a cube. Are yarn tufts infallible and indisputable? Did these blimp derived shapes of the 1930's use yarn tufts at all to arrive at their shapes or to collect data? Do present day automobile manufactures with wind tunnels use yarn tufts? If yarn tufts are 90% accurate, that would leave 10% on the table, room for improvement. How close to idea are yarn tufts? EDIT-1 Looks like back in 2001 NASA was using polyester not wool, and glued not taped with very specific procedures and requirements such a syringes to keep the glue glob size down. PDF Download: https://www.google.com/url?sa=t&rct=...Ft9VnAkyPjVl77 .................................................. ..................................... EDIT-2 https://media.springernature.com/lw6..._Fig2_HTML.png Getting an error on providing a link for the above image, found via Google image search with phrase "aerodynamic tuft accuracy". I assume it's showing reaction sensitivity or response times of various tuft filaments. |
Does anyone here have access to a Mercedes A class sedan ?
The car has an excellent .22 Cd, yet not only deviates from the template, but also has a short trunk / boot that you would think would keep flow from reattaching. I seemed to recall it having quite a bit of tumblehome to the rear, and thought this maybe what helps the flow reattach, but after looking at one that my neighbpr has, I see that is not really such a big factor. The reason I am asking is to see if someone would be willing to do a tuft test at the rear of the car to show what happens with the airflow. * The .25 Cd LS-430 had an even steeper back window, but it has a longer trunk / boot that could help the air to reattach. * or some CFD images of the rear of the car. |
Jul 27, 2018
Mercedes-Benz A-Class sedan has lowest drag-coefficient of any production car https://www.firstpost.com/tech/auto-...r-4822801.html Quote:
https://www.mercedes-benz.com/en/veh...-class-saloon/ http://forums.pelicanparts.com/uploa...1605313273.jpg http://forums.pelicanparts.com/uploa...1605313273.jpg Quote:
People don't change.
It only took 10:29 to burn my dinner. :( I think I punched in 4000 on the microwave. Anyway, I assert you have fallen into the same pitfall as others. Nobody looks at the front view with it's hemicircular profile. It's as hard and fast a rule as the profile. It makes it a proper windshield header for side-by-side seating difficult. VW Beetle has an optimal profile with a flat windshield for optical clarity (ignore the blind spots behind the A-pillars). Anyways, I made an argument for a superelliptic profile here. I noticed that Blender's geodesic generator has superilleptic options. Maybe I should revisit that. edit: I found Ducted radiators for low drag more helpful. So what do you think of the difference between a velocity driven radiator system vs a power-driven fan and air cooling? IIRC VWs boxer four had 1500cu ft/min displacement to work with. |
1 Attachment(s)
Am I the only one to notice that you aren't even using the current version of "the template" and that some of the pictures of cars in your video fit the AST-II?
Do you really believe what you stated in the video that aerodynamics works off the ratio of photographed dust in a wake balanced against a perpendicular vector of the rear angle? |
If it means "aerodynamic drag" then yes, a reduction in wake size (usually giving less drag) is one of the things that needs to be balanced in the rear extension design against the created lift-induced drag component (that gives more drag). In the case of the photographed Roomster, too steep an extension angle (note: still with attached flow) gave higher measured drag, despite the smaller wake. Incidentally, that Roomster example is in my aero book, and was specifically cited by three of the professional aerodynamicists who reviewed the book as a good example. In fact Dr Hucho liked the Roomster wake pics so much that he asked me for high res versions. |
Freebeard, I never just guess stuff. I measure things, and I read formal references. I know it's become de rigueur on this sub-group to knowledgeably pontificate in a context completely absent of any actual evidence, but I am not part of that. Answer to your question: I have no idea. |
Apologies I did not precisely define all terms in my question. I do not understand your correlation of a photographed wake size to drag, as a photograph can not lend insight into how the airflows that become the wake are exerting pressure on the vehicle. I realize that your post acknowledges the effects of the steep extension not aligning with this expected result of smaller wake equals lower drag. I am aware of what is in your aero book, seeing as how I own a copy. Care to comment on why there are so many examples of modifications made to match "the template" in the DIY section? |
Basically, people here have been sucked-in over a long period of time by a completely fallacious approach, vehemently argued by someone who hasn't even read a professional aero textbook more recent than 1987. As I said in the video, you need do only the most rudimentary testing on a variety of cars to see that much of what is said here about the template is just rubbish. It's no coincidence that those people here who have actually done that testing are also those that most question the validity of the template approach. |
Fair enough. I'm down to one Beetle anyway. It's still a pile of parts, I'll have to come up with my own d*mn plan.
If I had your resources I could test a Coanda nozzle and vent the exhaust into the wake of the rear tires. Just to see what happens. I wondered about the yellow arrow as well. It appears to be a normal, but I suspect you intended a resultant vector. Are you assuming Ecomodder is always and only about templates? Maybe you should get out more. |
But to be fair, my aerodynamics reference materials cost more (spread over 25 years) and my home workshop cost a lot (spread over 35 years). But what you are describing shouldn't cost much. All car modification has costs, so I figure if you're broke it's not a good hobby to want to pursue! These days, I spend $1000 a year on modifying my Insight. Bought the new lower ratios gearbox about a year ago, and just last week bought the clutch and gearbox rebuild kits. So that's the thousand for this year. Quote:
I have built and tested several "angled extensions" on several vehicles, the results are already documented on this site. Results logged over many thousands of miles. Does this qualify as the most rudimentary testing? I have several "basic shapes" saved that I use in my planning. Tools in a toolbox for design. I do not have the time or computing/testing resources to develop original aero designs from scratch. I am not hung up on proving any of them right or wrong. I have repeatedly used the AST-II and/or the AST top view and the resulting projects hit my projections for drag change reasonably closely and made the handling changes I desired. Thus I will continue using them. Since you apparently don't know, FYI there are photographs of "template based" projects in your book. You may want to edit them out in the second edition. |
https://ecomodder.com/forum/member-f...9-100-0629.jpg Quote:
It is claimed to allow you to: - Show where there is separated and attached flow on existing cars - Guide the shape of rear extensions - Show how rear spoilers on sedans should be positioned and shaped - Allow the assessment of the ‘aerodynamic purity’ of cars All these purported uses are simply rubbish! Quote:
Agreed about your four claims. I think what value the default template has is for canopies, blisters, aerocaps, external hinges & etc. With a higher fineness ratio.
This is as close as I could find a fit for the 'default' template: https://i.imgur.com/Ah5JdCu.jpg https://i.imgur.com/x1hiJcm.jpg A sectioned Type II could be center steer, between the front wheelwells. It fits the hemicircular front profile. My "Template": https://i.imgur.com/5jTnVud.png Three-quarters the wheelwell drag, but it needs to be truncated to a box cavity. |
Julian, please take a deep breath and DO NOT reply to my post.
We are lucky to have a template from (as I understand it) a retired professor. It's been useful in many cases. I'm sure it's not perfect for all cases but it's the best tool contributed so far. I would welcome some input from somebody else about evidence or scientific basis behind the template. Edit: here's the background for the template. https://ecomodder.com/forum/showthre...rt-c-9287.html Now that disagreement has been expressed I hope we can move on. |
I placed Sunraycer under the template,it was a perfect match.Bill Watson's airship "White-Dwarf" of 1984 is about 2.57:1 ratio. Watson worked with Burt Hibbs,aerodynamacist for Sunraycer. Both of AeroVironment. This shape seems to end up on some of the most efficient vehicles known in the world,I believe it to be a shoe -in for aero-modding.Those with more advanced aerodynamic toolbags will will no doubt venture out into some of the more exotic shapes,but for amateurs,I believe this form can serve us well. |
I would like you to realize that your opinion has been expressed. The personal attacks should stop. Find something else to talk about. Is that unreasonable?
The debate has never been whether the template is a low drag shape. It’s one of at least five in the literature - all with quite different shapes. |
I am criticising the spreading of misinformation that is leading people astray. Or would you seriously rather that misinformation keeps being spread without being challenged? Why don’t you address the specific criticisms I have of the template approach? I listed them above. |
So just confirm for me, you really would rather that misinformation from an individual goes unchallenged? Really? If you think the template, as used here, is great, why not address my specific criticisms of it? |
OK, I'll watch the video.
0:23s : "apparently ideal shape" -- I've never seen anybody here claim that. The original description doesn't claim that. 2:10 : you're right, the template doesn't predict where the flow detaches to a high degree of accuracy. It's maybe 20cm off or so. Big whoop. Nobody claimed the template was perfect, it's an approximation. The original description even says, it should be useful for amateurs. 2:53 : "there's a small separation bubble at the rear of the window". Big whoop. Probably caused by the antenna. 4:41 "testing beats following every template" : yep, agree. If you have time to do so 7:54 The Sagitta and the Taycan look really close to the template to me. Not perfect. In summary, the template isn't perfect. OK, great. What are we fighting about here? |
It is claimed to allow you to: - Show where there is separated and attached flow on existing cars - Guide the shape of rear extensions - Show how rear spoilers on sedans should be positioned and shaped - Allow the assessment of the ‘aerodynamic purity’ of cars All these purported uses are simply rubbish! |
I agreed with you at permalink #18.
[crickets] I think your aggrieved 'come at me bro' attitude is tiring. But.... The forum is pretty much dead except for this 'controversy' and The Lounge, so.... |
I guess we have very different opinions on the meaning of "rubbish" and "approximation".
I don't mean to be a dick online. Have a good night (/day in Australia). |
People who have the equivalent (non) argument of “I don’t like you so please be quiet” is one reason misinformation has flourished here. |
I've already acknowledged that the template isn't a perfect tool. That holds for all four of your bullet points.
Clearly it is a useful tool that provides a good approximation. |
Viz: It is claimed to allow you to: - Show where there is separated and attached flow on existing cars This is very much yes/no - is the flow attached or separated? The template definitely does not show this on cars. - Guide the shape of rear extensions Absolutely not. The best shape rear extension will depend on a whole lot of factors, and following a preset template is no guide at all to gaining the best outcome. - Show how rear spoilers on sedans should be positioned and shaped Completely wrong. This confusion shown by Aerohead when describing how rear spoilers work is based on his belief in the template (and how rear spoilers worked on old cars), and following that advice will give terrible outcomes on any modern sedan. - Allow the assessment of the ‘aerodynamic purity’ of cars The idea that, if only car makers followed the template they would get so much better results, is complete rubbish. Therefore, overlaying a car and 'measuring it' against the template (to purportedly see how good the car is) is equal baloney. After all, why not pick one of the other five low drag shapes with which to do the comparison? The template is just one of a bunch of different, low drag, theoretical shapes. If it were presented as that, then that would be quite correct, and I'd have no issues. I don't know, maybe it started off like that - but it's certainly gone into crazy land since! |
I worked 8 years as a school teacher, another 8 as an adult trainer, and been modifying cars (and writing about it) for 35+ years. And I hate people being given the wrong information. But that doesn't mean that there is not room for disagreement. For example, Vman455 and I disagree on the purpose/presence of vestigial front spoilers on modern cars - but I think it's a literally debatable point. On this sub-forum people are talking information that is so often wrong it's gobsmacking. I can even read individual participant's posts and immediately recognise where their aero misapprehensions have come from - because those misapprehensions are here and nowhere else. (In other words, this sub forum has developed a whole bunch of uniquely wrong 'understandings' of car aero.) I know some people who have posted here know far better, but either they can't be bothered posting corrections (especially when they'll be met with a wall of pseudo-tech BS from someone who apparently believes they're always right) or the peer pressure 'to be nice' keeps them quiet. (Obviously that's not me!) Unfortunately I cannot see any change unless people start to do some decent on-road testing (throttle-stop, tufting, pressure measurement), read current aero textbooks or step out of the 'cult' (as someone described Ecomodder to me) frame of reference. None of these actions takes much money, but they all require an effort. |
I see Template Worship as one [misguided?] theme, alongside A-B-A testing, hypermiling and a number of others. Frankly, since I don't drive much anymore, I'm in it for the friendly persuasion in The Lounge. |
For a more recent example, look at the Honda CR-Z build thread. In that one, a poster writes about his efforts to obtain a high-resolution profile photo so he can "analyze" the car aerodynamically--presumably by comparison to the "template" (as if it is possible to "analyze" a car aerodynamically simply by looking at a picture of it). *** I don't understand the pushback here. Whenever Julian has recommended a book, I've bought and read it. I bought the (inexpensive) testing equipment he has posted about. I've started measuring things myself; I don't have to take his word or any author's word for it. I've learned a great deal in the process, but most of all it has opened up a whole world of what I don't know. What are you all afraid of? Are you afraid your previous beliefs about aerodynamics will have to be rethought? Do you think you'll "regret" learning something new, as someone threatened in another thread (under different circumstances, but the sentiment is what I'm getting at)? Or is it just that the idea that the field of vehicle aerodynamics is actually simple (an idea which appears to be so far from the truth as to be laughable), which has been promulgated on this site for more than a decade, is now so entrenched that you all truly believe it and no contrary evidence will be tolerated let alone investigated? What is it? |
Ironically, aerohead is one of the few people who actually took the time, his time, to provide some feedback in my build thread; yet people have the audacity to criticize him ? Where are the other viewpoints ? oh wait... they are too busy denigrating. aerohead is not selling anything. Mr Edgar is. Keep that in mind. |
