Old 07-21-2015, 01:31 AM   #1 (permalink)
Aerodynamic mods and their effects, and dimples!
This PDF file tracks what changes were made and the effect upon CD:
http://www2.warwick.ac.uk/fac/sci/wm...tion120221.pdf
This one examines drag reduction by surface dimples:
http://waset.org/publications/100008...urface-dimples
(Note: if you can't get the second PDF file to open in Chrome, it'll open in IE)
The Following User Says Thank You to Cycle For This Useful Post:
aerohead (07-22-2015)
Old 07-21-2015, 04:42 AM   #2 (permalink)
The first PDF appears to be a newer version of the Coventry University slides. There are changes from the version I'd seen, like a new example in the box cavity section.
It would be interesting to hear the lecture[s] they support.
Old 07-21-2015, 11:36 AM   #3 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The dimple study has dubious application to real-world cars, I think. Their analysis only shows what we already know: where airflow is detaching from an object, adding a dimple (or a vortex generator) will delay flow separation by adding energy to the airflow. The problem here is, the authors did not investigate the effect of multiple dimples on the shape of an actual car, just one dimple on a small part of a very simple body.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 07-21-2015, 04:06 PM   #4 (permalink)
I find it interesting that they say annular rings around the wheels can be more effective than pizza-pan discs.
Old 07-22-2015, 04:37 PM   #5 (permalink)
dimples
The investigators apparently weren't aware that better vortex generators exist than dimples.
Old 07-22-2015, 04:41 PM   #6 (permalink)
pizza pans
It looks like the investigators tested flat discs,rather than pizza pans which protrude away from the wheel a bit,or MOON-type covers which are convex.
For 100% coverage,the flat disc appears to outperform the annular rings.
freebeard (07-23-2015)
