Waters' streamlined brick
This is from D.M.Waters' research,which appears in Hucho's section on RV travel trailers.
Waters tested the drag of a rectangular box with progressive rounding of all edges. The drag is a function of the size of the radii,expressed as a percentage of the square-root of the frontal area. For simplicity,I've used a rectangle of equal width/height. Three views are represented: side elevation at bottom,plan-view above it,and front elevation to the lower left. You may see a similarity to Airstream type bodies. http://i1271.photobucket.com/albums/...itled12_12.jpg http://i1271.photobucket.com/albums/...itled11_12.jpg http://i1271.photobucket.com/albums/...itled10_12.jpg http://i1271.photobucket.com/albums/...titled9_12.jpg http://i1271.photobucket.com/albums/...titled8_12.jpg http://i1271.photobucket.com/albums/...titled7_12.jpg From Waters' curve,the drag minimum occurs when the radii are equal to 39% of the square root of the frontal area.(lower than a cylinder with two convex hemisphere's tacked on each face). ------------------------------------------------------------------------- Here you see how E.M'o'ller softened the original Volkswagen delivery van of 1951 to shave the coefficient of aerodynamic drag from Cd 0.76,to Cd 0.42. http://i1271.photobucket.com/albums/...titled4_13.jpg http://i1271.photobucket.com/albums/...titled6_13.jpg This is a 'guess' as to what M'o'llers model may have looked like.The data is very limited http://i1271.photobucket.com/albums/...itled13_12.jpg Wolf Heinrich Hucho experienced similar results during the wind tunnel development of the Volkswagen Vanagon in 1969. |
Love it.! you get to the pill shape and the CD goes up a touch :)
Any speculation on why the 39% radius has the advantage?
Here's my attempt to put front wheel skirts on that microbus nose: http://ecomodder.com/forum/member-fr...ocalmotive.jpg |
