Wax and varnish removal from gasoline?
What will happen if I remove wax and varnish from gasoline?
What?? The world will end?? I give up. Please tell me...
1 Attachment(s)
I'm no chemist, so help me out here.
Where in the chemicals that make up gasoline is the "wax and varnish?" Attachment 5341 Material Safety Data Sheet. I did find this dealing with heavy lubricants used in oil production equipment: "Guardex Stuffing Box Oil is a specially formulated lubricant, designed as a rod and packing lubricant for both centrifugal and reciprocation action pumps and equipment. The additives in Guardex Stuffing Box Oil breaks down and controls wax and varnish build-up, while providing a superior film of lubricant on the rod surface. Guardex Stuffing Box Oil lubricates and prolongs the service period of packing and seals, while anti-corrosion additives help combat environmental corrosion such as H2S or salt water. "Recommended Uses Guardex Stuffing Box Oil is recommended for use in all drip oilers or tank oil systems, for lubrication of pump rods and packing. "Advantages *Superior lubrication *Eliminates wax and varnish build-up on rods *Extends packing life *Equally effective on reciprocating and centrifugal rods *Combats corrosion (eg. H2S, salt water, etc.) *Extend life of equipment Guardex I'm not seeing a connection with gasoline. |
Old gas leaves gook commonly referred to as gum and/or varnish. Not sure about "wax" but whatever.
I've just been dealing with that exact issue. I'm resurrecting a freekin' Gold Wing which has been sitting for many, many years (10?) but not pickled for storage. :mad: #4 carb needle was stuck open, dumping much raw fuel into intake and some made it to crankcase too I'm sure. Yeah, motorcycle carbs... I only wanted to drop the float bowls and examine floats and needles BUT NO, the manual says disassemble the entire motorcycle to get those bowls off cuz the carbs are all siamesed together! :mad: To **** with that, with the ingenuity of MacGyver and the skill of a surgeon, I removed the worst offender's bowl, swiped a mirror off the x-girlfriend's makeup compact, and got er done with no other disassembly. Oh... right... the point of the post. Lots of gum and varnish kept the needle from moving up and down in the seat. Had to physically scrape it off (knife, scotchpad) and chemically clean the rest of the residue with carb cleaner. Sparkplugs told me the right bank was OK, so that left #2 as "doubtful". Got some gas additive "carb cleaner" and let her have a super concentrated shot of it. 3rd day now and it's running fine! :thumbup: |
So, taking out the "wax and varnish" means taking the gas out of gasoline. :D Not sure a car can run on "oline" only. :p |
I'm designing a filter guaranteed to remove the wax from gasoline, but it's going to be expensive. I can also make it to remove varnish, but that will cost extra. PM me your credit card number...
Phord: Are you talking about older gas or new gas? |
I use alcohol. But don't forget to change your fuel filter.
I read that the burning wax and varnish are the major source of pollution and that is the ethanol is the added to help them burn properly, and distilled gasoline should be clear colored (not yellowish) and the filter is easy to make (big fuel filter filled with coconut charcoal powder and activated charcoal powder) . So if the filter works there will be no deposits in engine and the oil lasts longer interwals and this results in the longer engine life right?
