Were my tires throwing off my fuel logs? Help
1 Attachment(s)
Hey I was looking at a profile on here where someone said that the tires on their car or whatever it was were 6% bigger then the stock so he calculated the 6% into the fuel logs for 6% addition to the miles driven. The tires I had on for a while are 10% bigger then the stock/ones I have on now. Was I suppose to add in that 10% :confused:
http://ecomodder.com/forum/attachmen...1&d=1249782310 |
Yes. :P You screwed up.
What you actually have to do is calculate the difference in rolling circumference, not diameter. You add in the % difference of the circumference, since you've gone that much further. |
If your tires were 10% bigger circ, you add 10% to the miles driven.
If so then for ex. if I drove 300 miles I should take 10% from 300 and add it to the 300, that being 330 and put 330 in the place of the 300 right? |
:thumbup:
It'll show better mileage... more distance on the same fuel.
