What about placing radiators in the back to fill-up Kamm low rear pressure?
What you guys think of an aero design that places the radiators (and maybe even the exhaust) at the back of the car?
So their heated air (thus with high pressure) compensates rear low pressure zones? Remember piston engines are at most 30% efficient. So most fuel is wasted as heat. What about using this lost heat to improve aerodynamics? Many formula cars try to place radiators in the sidepods to minimize cooling drag. What about a similar design for front-engined cars? Maybe you'll need to place radiators in the back instead, so you can still use the sides to open the doors? |
I have thought about it - two problems. One, you need flow THROUGH the radiator to cool it. Hard to get flow through the radiator back there.
As for exiting the hot air back to the dead spot, good idea I think. |
This has actually been used in piston-engined aircraft, notably the P-51 Mustang. See Meredith Effect - Wikipedia, the free encyclopedia
As for input air, why not ducts in the sides of the car? And then you could make it mid-engined, kinda like this: Lotus Elise - Wikipedia, the free encyclopedia |
Hillman in the 1960's built a rear engined car named the Imp which had a radiator ducting into the rear panel and the intake was on the rear deck where the trunk / boot would normally be.
Apart from adding a little weight at the rear and having the extra pipework to take the fluids to and fro there seems to be few downsides. Peter. |
Ford
I wonder if this would even be worth it, especially if you have a front-engine layout. What with the plumbing necessary to cycle the water, the extra weight from the extra liquid, and the reduced airflow.
*(I should acknowledge of course that the Merlins used in the Spitfire were pretty much "hand built" due to the design which was very inefficient for production. The P-51 version of the Merlin (redesigned in the US during WW2) was transformed into a mass produced engine, and improved along the way. Created by geniuses, improved by very smart engineers.) |
http://worldwartwozone.com/aussie-da...ttom.thumb.jpg |
