what do guys think about Titanium fasteners?
the cost pretty high but half the weight...i was thinking of replacing just a few bolts... on some rotating parts...
water pump pulley x 4bolts ...switch to a light weight pulley drive shaft x 4bolts..............switch from a 24 lbs to a 13 lbs wheels x 80 bolts.................stock steelies was about 40 lbs each 14x6 new wheel 15x9 F 15x11 R ..(rears are 17lbs each ..fronts are 15lbs each)..i still have to get tires for them to get the full weight and may be a few here & there on the suspension...to loose some unsprung weight http://ep.yimg.com/ca/I/yhst-4332575..._2182_95450942 http://ep.yimg.com/ca/I/yhst-4332575...2182_197506029 http://ep.yimg.com/ca/I/yhst-4332575...7_2227_6261514 |
Any gains will more than be lost by overly wide wheels. What type of car is this for? 11 inch wide wheels is drag racing territory. Otherwise seems like small gains for the price when talking fasteners. Only for sponsored race cars.
Sounds interesting. Surely there are plenty of hachi-roku parts to choose from. Whatever the racers do for weight savings will surely work for hypermiling, and some of the suspension work will help too (not camber, etc). It should be said that it's unlikely for these lightweight bolts to pay off, but if it's not about return on investment through gas savings I say go ahead. The worst they can do is make your car a little bit faster and your wallet a little bit thinner.
Are you stretching skinnier tires onto the rims or using super wide tires? I have thought about stretching LRR tires for the look and function. 8) |
Will it help? Yes, but you'll never notice the difference.
Do they come in titanium-colored?
its a for 1986 corolla w/ jdm 4agze swap (supercharged @ 14-15psi) im guessing i could kill a pound or two on each wheel by swapping the bolts...to cut down rotation mass. http://sphotos-a.xx.fbcdn.net/hphoto...41948887_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...35135034_n.jpg |
...and speed-enhancing aero aids. http://ijdmtoy.com/ebay/Misc/Decal/J...-decal-129.jpg
what i can i do to make the car more efficient im willing to do....and i did alot big things all ready...the little thing is where its going to count.....my goal is lay a ass whopping to the higher hp cars :) im around 220-250 hp body weight is around 1850-1900 lbs |
-soD |
trying to reach this caliber...in Japan these are well respected machines...
and have huge a cult following ..around the world..it caught in the sates in 2000 ..this is the car that put drifting on the map....but it's used in many other race series http://sphotos-b.xx.fbcdn.net/hphoto...48410593_n.jpg http://sphotos-a.xx.fbcdn.net/hphoto...45761215_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...24973250_n.jpg |
The next reincarnation and the good karma follows into the new hachi-roku - Toyota 86/ EU GT86/ our NA FR-S. By all accounts, the best for contemporary value/performance/most important - enjoyment. http://i1078.photobucket.com/albums/...S/4133c93b.jpg |
from experience here with lightening a car, cheap way take every bolt in the car, and cut it to just the right length to go through the fastener plus one full thread, that;s the spec for race tech approval if i remember, oversize wheels and tires will slow you down, go just as big as you need for the track . that's why drag racers and others run front skinnies, every bracket you can remove can be lightened by drilling the areas not needed for strength , edges can be radiused and smoothed with a grinder and of course all insulation and carpet thinned out , Got my 66 Mustang v8 down to 2650 full of gas and went pretty good. even with the iron heads and 4 speed. most 5.0's are around 3000 lbs, titanium sounds trick but really not worth it far as I can see, Save your money for gas and toys for the little one ,
This is performance only territory; in fuel savings you'll sadly never gain back the investment.
The one nut on which weight reduction might really affect MPG, in most cases, would be the one that holds the steering wheel. Or opens a can of soda. You get the picture. |
EC Works Manual Mirrors 8.4 oz (x 2) 1lb 0.8 oz vs stock power mirror 2 lbs 13.4 oz (x2) 4 lbs 5.4 oz http://sphotos-b.xx.fbcdn.net/hphoto..._1973546_n.jpg door hinges http://sphotos-b.xx.fbcdn.net/hphoto...2_654058_n.jpg hood hinges http://sphotos-b.xx.fbcdn.net/hphoto..._6017021_n.jpg center consel http://sphotos-a.xx.fbcdn.net/hphoto..._1210102_n.jpg and some other parts...also replaced the doors hood hatch with carbon fiber also with lighter suspension parts http://sphotos-a.xx.fbcdn.net/hphoto..._1623600_n.jpg |
http://ep.yimg.com/ca/I/yhst-4332575..._2182_95067533 |
Remember, mass that is close to the center of rotation has less effect than mass out away from the center. -soD |
Those fasteners will earn you some scene points in the show/ drifting circles. Here on ecomodder scene points are earned with junkyard finds and spreadsheets. Good luck though. That is some nice work so far.
11 inch wheels for 250hp? I'm no suspension/racing expert but that seems a bit much. The wheel and bolt-on arch look really great (!) but is it worth the extra rotational mass? Are you an autocross geek? Track-day kinda person? Or is it going to be more street car than anything?
I understand doing it for looks. Because it'll look really, really good. But it seems a bit strange to come on here and ask if a few pounds of weight savings will improve your fuel economy on a 4AG track toy with oversized wheels. Because while many here race, we convene on this forum to talk about economy. |
http://ep.yimg.com/ca/I/yhst-4332575...2182_131606384 |
the rim only weighs 17lbs for a 15x11inch wide the front are 15 lbs..these are ssr's very are light and rare. the tire should add another 10lbs .i found a guy that was selling these and i jump on it ..you cant find these this size / offset in the states...stock was around 40lbs for a 14x6 inch rim/tire lol ae86 circuit cars run 10 in the rear and 9 or 8 in the front ....here is a vid you''ll see what they are using..& i planning to get aem water meth kit whicj add another 25hp when needed.. i might go turbo later on 300-350 or swap in a 2jz or a 1uzfe if money really plays right.... http://youtu.be/cEvePfeD3bc |
there some guys out there running 15x12, 15x13 & 15x14....but that is just straight out for balling purposes on cressidas crowns soarers ect..lol
out here is the taller you go 20's -24 ect.... out in japan it goes by how wide you go... |
I think titanium fastners make sense in aircraft and cost is no object racing. I think they are a ridiculous waste on money otherwise.
The thing with titanium is its half the weight of steel, not as strong and some where around 100x the cost.
The only place I could consider the extreme cost of titanium is in some suspention parts. If weight saving is the name of the game then use carbon fiber where possible. |
4 water pump pulley 4 drive shaft 80 on the wheels |
If you want titanium suspention parts you are likely going to have to make them your self of comission someone to make them for you.
I used to copy suspention suspention parts in titanium. |
i also looked into titanium headers $1200 & $catbacks 1200 7lbs each stock exhaust weigh around 45 lbs im currently around 25 lbs full exhaust .. do you still copy parts in titanium? |
I don't doubt that 86's are great cars. They are. But I can't help thinking your money and effort might be better spent elsewhere. If you're truly saving 11lbs. on the driveshaft bolts alone, it seems worthwhile. How much do the wheel bolts weigh? |
A recent scene in our neighborhood speedway, the very first 86Fest, with the best tuned 86's and most importantly the world's best 86 drivers. The best track/road performers had a balanced and very pragmatic setups. The ones with most expensive parts and unobtanium materials were strictly for aftermarket product trade shows and magazine photoshoots.
86FEST: the ultimate festival for Scion FRS, Subaru BRZ, & Toyota AE86 enthusiasts New school - http://i.imgur.com/klhXl.jpg |
Sounds like you've got it all figured out then! (Why not get the carbon painted to match?) :)
here is a pic of carbon that has been color matched http://i73.photobucket.com/albums/i2...w/c36efb78.jpg |
Rally drivers go 55mph from stage to stage because getting pulled over DNF's their entire day. Go the speed limit, follow laws and they'll have no reason to pull you over! :)
(But really, do what you want!) |
