EcoModder.com
-   Hypermiling / EcoDriver's Ed (https://ecomodder.com/forum/hypermiling-ecodrivers-ed.html)
-   -   what else can i do to improve fc? (https://ecomodder.com/forum/showthread.php/what-else-can-i-do-improve-fc-3704.html)
spyghost 07-11-2008 10:08 AM
hi,
i've managed to consume 15Km/L from my recent measurement. the fastest route that i can take can only give me a top of 60kph for around 5 seconds. i don't go through highways in my daily drive - only within the city.
so far, what i have done is p&g, coasting in neutral, shut off engine at stop light, gradual acceleration, right tire pressure (i don't want to go higher than factory specs).
my car is all stock (no performance mods), recently tuned up (new oil, oil filter, air cleaner, fuel filter, plugs). timing is stock advance. carb is newly rebuilt.
afaik, aero mods won't do me any good since i can't go higher speeds.
azraelswrd 07-11-2008 12:19 PM
Even some aero mods can't hurt though you're right -- they make a bigger impact as speed increases. In lower speeds, tires become more important. If you're comfortable with the pressure have you considered getting low-rolling resistance tires?
Do you have a way to get instaneous feedback on your driving? A Scangauge II could help you "calibrate" your driving techniques and tune where you can get the most bang for your FE by giving you the information to you at that moment.
Figjam74 07-11-2008 12:22 PM
15km/L in city? I'd say you're doing really well. The 'nut behind the wheel' has been finely tuned. Your biggest improvements now are probably going to be from Low Rolling Resistance tires, and reduced weight.
spyghost 07-11-2008 06:01 PM
i can't use scangauge. i am using a carb engine. i'll be looking for a vacuum gauge
spyghost 07-11-2008 06:03 PM
as of weight reduction, what can you suggest? i am all stock - that is no modifications of any sort. so far, i am carrying with me my spare tire, scissor jack, and a socket wrench for the tire. i can't live without having a spare, although its a good weight reduction.
dcb 07-11-2008 06:24 PM
The car factory or tire factory? You might have some mpg gains waiting for you right there.
elhigh 07-11-2008 07:58 PM
You're pushing past 30mpg in town, I'd say you're doing great.
If you're doing that much getting about in town, how much could you offset with alternate modes, like a scooter or bike? Bikes with add-on motors can shut down on hop onto bike trails for the ultimate in convenience.
spyghost 07-12-2008 09:00 AM
car factory. my car manual suggest a 28 psi in front and 26 behind. higher than that, im feeling jerky.
Figjam74 07-14-2008 12:00 PM
How much do you want to spend? How hardcore do you want to be?
Comprehensive guide on a drifting forum (Mild to Hardcore)
My advice would be to start pricing lighterweight components to be replaced as they fail (seeing as it's almost 10 years old already). Things like suspension and exhaust are good candidates since they tend to be the things that wear out first.
spyghost 07-14-2008 07:58 PM
so far, i have already changed the shock absorbers and the coil springs to new ones. i switched to replacement parts. in this way, i am still maintaining my stock height. the only difference is that i came from a fluid type of shock absorbers. now i am using a gas-type kyb excel-g
bryn 07-14-2008 08:18 PM
can you change when you drive, for less traffic?
bryn 07-14-2008 08:22 PM
do you havea way to look at you air fuel mixture? with a carb you may be able to adjust it for economy vs performance. without getting too lean
spyghost 07-14-2008 10:59 PM
well, traffic is something i have to live with. i've scanned several routes and i've already found the best possible.
spyghost 07-14-2008 11:00 PM
unfortunately, being a carb engine, i do not have an o2 sensor. the narrowband is also quite pricey.
spyghost 07-17-2008 08:12 PM
I just refilled my fuel this morning and I can't break my record
http://ecomodder.com/forum/fe-graphs/graph981.gif
