What factory car is the steady state, 65 mph, MPG champion?
I was reading the thread on replacing a VX with a G1 Insight and it got me thinking. What is the best car ever MPG wise at a steady 65 mph? One of the old TDI's or a newer Cruise diesel maybe? I'm talking a readily available production car in it's basic form, LRR tires aired up, a grill block and wheel covers, a custom tune, maybe an air dam, but not a total redesign, home build, or powertrain swap.
hmm, diesel Chevette? Ford Escort diesel? are two to pop in my head from my youth that were great, or would you want a gas engine?
Easy.
Any electric car. Even my unaerodynamic leaf does around 140 mpge at 65mph. |
At 65 mph, aerodynamics will have enough of an effect that I doubt anything would beat a 1st gen Honda insight.
However, for a non-routine trip, there are a few vehicles I would pick instead of a 1st gen insight. |
Since you said miles per gallon, I'm assuming plug-in hybrids and electric cars do not count.
In that case the Gen 1 Honda Insight manual transmission would take the cake. It has one of the lowest drag-coefficients of any modern car, along with one of the most efficient engines. I have observed 70-80 MPG cruising at 65 MPH on the highway, if the wind isn't against me, in 40 F degree weather. If you take into consideration plug-in hybrids and electric cars, then we're talking about miles per dollar, which is an entirely different scenario, since electricity costs are not directly related to gasoline costs in every area. |
Honda also made a special version of the CRX in early years with better mileage. this will be slightly off topic, but probably first you will hear of it, in early 1980's Dodge & Plymouth made a car called a Omni, or Horizon, nothing special, & everyone thinks about the 2.2 liter OHC engine, however!!! they also offered a gasoline Peugeot 4 cylinder 1.6 liter cam in block in those cars, very very rare, I have 1 I started parting out, but could snap pics of engine as drivetrain is still I it. it got 45-50 with a 4 speed, always wondered what it would have done with a 5 speed over drive & tweak engine for a hair more power. |
Nothing beats the pure electric in cost per mile as pointed out especially here as we have about $0.06 per Kwh electricity. Just the range doesn't make them a good Montana highway car. |
