what r those wheel shrouds called?
u can do a google image search for "suzuki hatch" to see what it looks like..
circa 1983, its electric with the aerodynamics of a brick.. i put a flat piece of masonite under the body from the front to the back to make it flat and smooth to improve aero next step is to put those wheel wheel shroud things that cover the back wheels that everyone here does but i wanted to know what they are called so i can search for them easier and i also wanted to know how people attached them in such a way that you can change the tyre if need be |
wheel well skirts
Wheel skirts? I looked through https://www.google.com/search?q=suzu...w=1366&bih=672 and did not see anything unusual, but wheel skirts were standard on the Gen1 Insight.
Can you post a link to the image you're talking about?
Just leave off the "http://" part to get around the forum's link-posting restriction for new accounts. |
skirts
thankyou for the replies :)
i put a board under the car, side skirts and an air dam at the front the car now uses 105 amps to maintain 80kph instead of 110 but i also checked the tyre pressure and they were all down a few psi so it might have come from that ill be making the wheel skirts soon and i wanted to know what u guys think, what i could do to get the greatest benefit? boat tail? spoiler? lift the bonnet up a bit? google.com.au/search?q=suzuki+800&source=lnms&tbm=isch&sa=X&ved= 0CAcQ_AUoAWoVChMIvN6pm8n2xgIVaBemCh24qwMB&biw=1024 &bih=707#tbm=isch&q=suzuki+hatch+800 |
An example:
https://upload.wikimedia.org/wikiped...i_Alto_102.JPG Call me old-fashioned; but I'd say they're fender skirts. |
greatest benefit
The aft-body would offer the greatest drag reduction.You can see how streamlining allows huge bodies with no more drag than horribly-shaped tiny bodies.All-4 of the following bodies have identical drag
http://i1271.photobucket.com/albums/...titled11-1.jpg Here,you can see how Kamm et al. gets lower drag simply by extending the tail http://i1271.photobucket.com/albums/...titled10-2.jpg http://i1271.photobucket.com/albums/...ntitled3-3.jpg http://i1271.photobucket.com/albums/...d2/Scan3-1.jpg Here,Volkswagen can dial in a variety of drag coefficients simply by altering the hatch area http://i1271.photobucket.com/albums/...an01-18-14.jpg This pocket of low pressure behind the Suzuki just sucks your tank dry http://i1271.photobucket.com/albums/...ad2/Scans4.jpg Filling the dark blue area behind the car with boat tail makes this drag go away. http://i1271.photobucket.com/albums/...ad2/Scans2.jpg |
wow look at all that, such helpful responses :) thankyou so much guys
i was thinking to lift the hatch up so its in line with the aerofoil shape then make something to block in the gap, so it would be something like a kammback your thoughts? another thought i had would be to lower the back a bit, so the roof slopes down instead of being relatively flat |
