EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   what would this do? (https://ecomodder.com/forum/showthread.php/what-would-do-21023.html)
redorchestra 03-16-2012 06:17 PM
what would this do?
http://i45.photobucket.com/albums/f1...s/IMG_3021.jpg
what would this do? aerodynamically spaeaking ? would it be good bad unknown?. any idea why that lip sticks out at the bottom. I think it is well executed and good looking but whatgood is it?
Gealii 03-16-2012 06:33 PM
the lip i know is used in racing to provide down force in either speed or cornering but not sure for actual mileage
redorchestra 03-16-2012 06:37 PM
so would make the front of my car act heavier? I don't want heavy, but it does look good doesn't it. great execution
Gealii 03-16-2012 06:47 PM
i believe it would make it act heavier do not hold my word to that though, and yea the execution makes it look really nice
deathtrain 03-16-2012 07:54 PM
its a splitter. It is used in racing for front down force.
ChazInMT 03-16-2012 08:15 PM
If driven at high speed, it will make short work of mowing your yard. Just sayin.
Aerodynamically, it could be a good drag reduction add on as well during the time that it remains attached to the car.
Ladogaboy 03-16-2012 09:37 PM
The splitter is a bit short, but it should still help to produce some downforce. Look at it this way: As you drive faster, the air pressure at the front of the car becomes greater. The splitter catches that high pressure air and pushes the front of the car down (downforce). The longer the splitter, the better the leverage.
In terms of aerodynamics, it should also help because the farther the front of the car is pushed down, the less air can travel underneath it.
bikin' Ed 03-16-2012 09:54 PM
splitter / lip
The lip at the bottom helps to catch air being forced down from the bumper. It directs it around the side of the car rather than letting it go underneath. That keeps you more aero.
Sven7 03-16-2012 09:55 PM
Edit: Ed beat me to it! :)
It will divert air around the sides of the car instead of it tumbling around the aerodynamically dirty undercarriage. That's good. It should ideally stick down just far enough to shield the chassis and suspension components from oncoming wind, so it looks a little low to me. Perhaps cut an inch or two off the top edge and then install it. This is different for every car, so you'll have to eyeball it to see whether it's sticking down too much or not enough and modify accordingly.
As I understand it, downforce doesn't really make the car feel heavier as much as it just gives you more grip. It will increase your overall drag but make the car handle better. If you trim the thing right it will decrease your drag while maintaining basically the same handling. You're probably not going fast enough on the street for the downforce to make much of a difference anyway.
At the end of the day though you could probably get similar looks and the same aerodynamics out of black rubber lawn edging. Check out the Chevy Express van on here which did that and reported noticeable FE improvements.
Ladogaboy 03-16-2012 10:01 PM
The downforce at highway speeds might be significant, though. The amount the front end would dip would probably have more to do with the suspension/spring rates than anything else.
