EcoModder.com
-   -   What would you pick as your five top, tried and true, tips? (https://ecomodder.com/forum/showthread.php/what-would-you-pick-your-five-top-tried-2340.html)
SVOboy 05-14-2008 07:45 PM
Doing a little research for something (secret) that I'm writing. What all would you call the top 5 you would recommend to others?
Thanks!
-Benjamin
trikkonceptz 05-14-2008 07:52 PM
Here is my list;
1-Slow Down, to at least the speed limit
2-Increase tire pressure to max PSI rating or 50 psi which ever is safer for you
3-Learn to coast, stop speeding to a stop
4-Remove unecessary drag, roof racks, mudflaps, etc ..
5-Avoid Drive thrus
Those five so far have taken me from 27mpg to 41mpg, my log doesn't lie ... LOL
AndrewJ 05-14-2008 07:55 PM
1.) Slow down
2.) Don't idle
3.) Park in the periphery
4.) Look 3 traffic lights ahead
5.) Pump up your tires
reformed 05-14-2008 08:28 PM
1.Slow Down
2.Up the PSI in your tires to at least 45
3.EOC whenever possible
4.Don't idle unecessarily
5.Plan your stops
Johnny Mullet 05-14-2008 08:32 PM
Slow Down
Increase tire pressures
time red lights to keep momentum up
Unnecessary idling
Weight reduction
JohnnyGrey 05-14-2008 10:53 PM
You can find these same tips repeated ad nauseum every time a news outlet does a report on fuel economy. It's not much of a secret.
ihatejoefitz 05-15-2008 12:07 AM
Top five tips for...?:D
SVOboy 05-15-2008 12:15 AM
Yeah, but I'm not trying to get the same five tips as everyone else, I'm trying to dig up some of the less common sense, just as effective things.
Arminius 05-15-2008 12:19 AM
I'm not going to parrot what has been said, but I would put Scanguage first. It taught me what speeds are best and what routes are best. I could go the perfect speed on a poor route and get bad mileage.
ihatejoefitz 05-15-2008 12:23 AM
Most effective for me would be,
Visit ecomodder
read
cognitively process
make effort
repeat
