What's in your trunk?
When reading hyperyaris' thread about rear seat removal, I thought that there should be a thread in which everyone could brag about the junk in their trunk. Admitting it is the first step, etc. ;)
So here's what's in mine:
By getting rid of everything I don't really absolutely need may save an extra 5-10kg, but I think that what I have is a good minimum. |
Small tool kit, umbrella, dirt. The spare is under the false floor.
Jack, spare tire, bottle of oil, and 2 sleeping bags in the trunk.
Back seat has a bag of tools, including 3/8" socket set, couple of screw drivers and smaller pliers, vise grips, channel locks, a 1 foot section of pipe for a mini breaker bar, and a bunch of various nuts and bolts. And, a Tercel Haynes manual. |
...nada! I'm already aware that WEIGHT = FE loss, to the tune of about 1-2% per every 100 pounds (from EPA data).
...for those interested in *where* the EPA got this number, here's the basic equation: (w1/w2)^0.72 = (mpg2/mpg1) |
My trunk is clean but I plan to save 10 kg, I'm on a diet... :)
Golf clubs and golf shoes are the only thing I keep in my trunk that is not associated with the vehicle...(spare tire and jack are in false trunk with some small car cleaning supplies). The clubs weigh about 15 pounds...I am heavily addicted to golf and I'm ready to play at a moments notice...a weight allowance I am willing/have to make!
Whats in mine? Nada!
http://ecomodder.com/forum/member-vt...7-23072009.jpg Apart from the spare wheel and jack.... ollie |
I don't have a trunk - it's a hatchback. But what gets carried back there is (usually) one Border Collie (a bit over 50 lbs), her blanket, and a couple of empty grocery bags for when I need to stop at the store. The under-floor compartment has the usual spare tire, jack, &c, and tire chains in winter.
I go back and forth between keeping the spare tire & tools in the back, and having it empty. Currently they're in there. But the rear seat has been out of the car for quite a while now - over a year.
I'll tell you what WAS in my trunk as of 1 hour ago...
about 350 STINKIN POUNDS OF TOOLS!!!!!!!!! talk about sluggish, man! It took a lot longer to get to 50 than normal. and the back end was definitely lower and very rolly. but now that i have removed all of the chrome and steel, its a LOT better. ill give you the rough list.
1 steel trolley jack 1 set of wrenches from 5/32 to i think 1 7/8 1 set of wrenches from 5mm to 34mm 1 24 inch crescent wrench and multiple smaller ones (total of about 6) 2 1/2 inch torque wrenches 1 set of lug sockets files gear pullers several sets of regular sockets ratchets, tiedowns, etc 10 or 15 screwdrivers 1 tub of wheel bearing/brake grease 1 24 inch 1/2 drive breaker bar and of course the SPARE Well, you get the picture. HEAVY and i didn't realize i left it all in there 4 days ago! go figure. |
sheet metal
besides the battery, nothing!! i moved the battery to the trunk via heavy gauge jumper cable cord as a battery relocation project to open up room under the hood to install ductwork to pull warm air from behind the radiatordirectly to the intake and the battery was in the way. as far as the rest of the trunk I even removed the lining carpet to save weight, and why have a finished interior when nothing goes in there anyway.
My tools are in the trunk. Not absolutely all my tools, but most of my hand tools.
With a 50-60 mile commute and older cars, I've had occasions over the years where those tools allowed me to get home or to work. |
Junk.
Seriously, Quart of oil Spacesaver spare Jack Umbrella Jumper cables |
Yes, I've been through the following ritual: - I'd love to give y'all a lift, but I have only one empty seat. - But I thought your car is a 7-seater? - It is, but I have only one empty seat. (I'm bumping this thread, in case you haven't noticed...:p) |
But if the seats are out of the most eco car, the best carpooling/ridesharing option is DOA!
This varies from winter to summer.
Winter load: couple jugs of water, a couple MREs, one or two blankets, 300 pounds of sand (over the rear axle), tire chains, flashlight, 2 pr work gloves, carabeener, umbrella, ice scraper, microfiber cloth, jack, tow rope, jumper cables, spare drive belt, first aid kit, tissues, spare tire is behind rear axle. Summer load: flashlight, 1 pr work gloves, umbrella, microfiber cloth, jack, tow rope, jumper cables, spare drive belt, first aid kit, tissues, spare tire. |
In the trunk area:
space saver spare lug wrench bicycle - type air pump paper /plastic grocery bags old blanket bungee cords stuck to ceiling half quart of oil Hidden in compartments intended for parking light access: $5 socket set $5 wrench set electrical tape screwdrivers crescent wrench nut driver for sheetmetal screws on aeromods knife fluorescent cigarette - lighter powered light Hidden in compartments that used to house rear 6x9" speakers (blown so I removed them): scissor jack jumper cables old sweatshirt and baggy old jeans that I can wear over dress clothes if necessary In the rest of the car, I keep a tire gauge (duh!), several refilled bottles with water (for people or for the car to drink) an air freshner, two child car seats, a battery powered flashlight that also has red LED strobes in the front of the car; my daughter likes to play with it at night on road trips. Luckily LEDs don't use hardly any juice. I feel good that the back of the car looks empty of valuables; I never lock it. I need to add: needle nose and regular pliers I also like the idea that Piwoslaw mentioned - law requiring a fire extinguisher. I should get one too and make it easily accessible to others from outside. Maybe on the back of the hatch, under the Kammback, or maybe that would be too tempting to immature boys walking by. |
Formaldehyde, rope, roll of old carpet...
nothing much, except for spare tire+jack (about 10kg for that) and another 4-5 kg of few basic tools, wires, few bulbs, 500ml of screen wash (too much dust here in Cyprus so use the wipers daily despite no rain for 6-7 months/year) ...that's about it...
I removed my front passenger seat and it has opened up the car (99 Saturn SL2) considerably. The back seats are foldable and hide the stuff in the trunk. I can now easily carry things that are long like the 2x4x8 studs.
Stuff in the trunk includes the heavy full size spare and necessary tire changing tools. |
Used to not carry my spare, but I'm going to be going on a trip soon, and I don't want to forget. So,
Full-size spare Jack and lug wrench Can of fix-a-flat (for nails) Jumper Cables Gas can (empty) Funnel Towel Small elastic strap |
Jumper cables, and my spare.
The only time i usually have anything in my trunk is when I am going to the dump. |
LOL I wonder if anyone else caught this combination! :rolleyes: |
The truck:
Back seat 3/8 metric socket set, screw drivers, metric wrenches. small 12v air compressor Jack and lug wrench quart of oil Jumper cables First aid kit jump seats (fold into the sides) Full size spare under the bed. The bed (gets used as a work bench alot) hack saw Tape measure 3 pickets left over from fixing the fence dirt left over from moving dirt The Jeep enough tools to probably dismantle the whole thing (weighs about 20 lbs) Short handled shovel Tow chain Tow strap 48" high lift jack Matching spare 1 gallon pre mixed anti-freeze 1-2 quarts of oil spare ujoint bailing wire duct tape 10' fuel line with filter(left over from recovering from a break down on a trail) hose clamps TP Cinder block (step stool for wife) And its not even fully stocked yet. |
Let's see...
http://inlinethumb31.webshots.com/44...600x600Q85.jpg Seen: turnout gear (volunteer firefighter) dry socks spare t-shirt rope spotlight windshield reflector bungee cords under floor- spare tire, jack, cigarette plug powered compressor also usually a medical jumpbag and jumper cables that are in my wife's car since we used it for a trip this past weekend |
