Old 07-22-2009, 12:08 AM   #1 (permalink)
Yaris - '07 Yaris Liftback
Rear Removal
I removed the back seat and everthing else out of the back of my Yaris. All there is, is the factory sheet metal lol. It looks very utilitarian. I will measure mpg gain next tank.
Old 07-22-2009, 12:28 AM   #2 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Good luck with that.
Old 07-22-2009, 09:07 AM   #3 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
I just removed my back seats as well...along with over 100 lbs of extra tools, books, and other junk that was in the back and the trunk.
I don't know if it's because I'm driving my car less or because it's lighter, but I can notice something different when I drive it now, the clutch seems to catch faster, and it seems to handle better as well. Could just be in my head though, who knows.
Old 07-22-2009, 09:29 AM   #4 (permalink)
blueflame's Avatar
100lbs from a 2000lb car is like a 200lb person losing 10lbs.
Old 07-22-2009, 12:18 PM   #5 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Whenever I haul cargo I take the seats and cover out of the back (3x20kg+5kg) and keep them in the garage until I need to haul people. The whole setup weighs as much as one person and is only about 4% of the weight of the car without driver. Whether it really reduces my FE is a subject for discussion, but the car does seem to handle slightly differently. This may be b/c I can hear what's going on in the back, like fuel swooshing around in the tank.
Removing the spare would give another 20kg of savings, as would getting anal about carpets, plastic trim, unneeded wires and motors, speakers, etc.
Piwoslaw's Peugeot 307sw modding thread
Old 07-22-2009, 01:08 PM   #6 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Thats mad! I have been running without the back seat this past week and have noticed my P&G is much easier. Well, the pulse bit is anyway. It accelerates like a kart! However, it coasts down a little bit quicker so it probably cancels out. I have had to reset my scangauge at the same time so it's hard to tell if i had an improvement.
ollie
Old 07-22-2009, 05:25 PM   #7 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
OK, I've had this on my disk for years and this is a good place to finally use it
Here is another reason to keep the weight in the rear down:
Old 07-22-2009, 06:10 PM   #8 (permalink)
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
I have my nightly climb home to 4,650 feet, and 100 pounds makes a difference. I keep the vacuum gauge at a constant 6 in. hg while climbing, and with the tire chains, winter boots, eMac and miscellaneous junk removed from the trunk, I started averaging 2-3 mph faster at that constant load level.
Old 07-22-2009, 09:32 PM   #9 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
How's the interior noise? Did you do anything to cover the gas tank access port?
The Legacy has a sticker under the rear seat cushions, "Do not place cargo here before reinstalling seat cushions". It's also got brake and fuel lines, and wires back there.
The Insight has half of an electric car under the carpet in the back.
Old 07-22-2009, 09:52 PM   #10 (permalink)
McTimson's Avatar
Felix - '09 Yaris
There's definitely much more noise in my car now. It was lough enough before getting rid of the seats, which also apparently acted as sound dampeners. It definitely doesn't help that my exhaust is pieced together by Autozone clamps and pipe segments, or that there's a visible hole near my rear passenger side wheel well from the rust. But, I only have front speakers in my car, so with the volume turned up a little bit, I can ignore the noise.
And, I didn't cover up the gas tank access stuff. It's just sitting there. I haven't smelled anything yet, so I hope it's good.
100 lbs out of 2000 may only be like 10 lbs out of 200, but it's still 5% of the weight. And, most of the weight I removed was in the back of the car, so I suspect that the placement had more to do with the handling than just the weight of it.
The back seats (seat and seat back) only weigh like 20lbs, but I really had a ton of junk back there that I kept thinking was better suited for the car than the apartment...but I was definitely wrong.
There's another Tercel driver who is meticulous about weight savings, and has posted his results here. It's definitely a good baseline for seeing how much different things weigh, a few of them are surprising.
How to decide whether to remove rear spoiler to decrease drag, improve mileage MetroMPG Aerodynamics 91 07-05-2011 02:59 PM
Tuft Testing - "Vortekz" vortex generators on 2003 Jetta Rear Window Deezler Aerodynamics 22 09-04-2010 02:10 PM
Dual Fuel, electric rear wheel drive, gasoline front wheel drive bucknmusky DIY / How-to 36 07-15-2009 11:45 AM
Rear Alignment: Drivability vs Economy Southcross EcoModding Central 11 04-22-2009 10:40 PM
tigra AERO PROJECT rear end question fabrio. Aerodynamics 19 03-31-2008 01:01 PM
