white metal roof vs traditional silver metal
i'm thinking of putting a metal roof on my house and i dont know which color would be more efficient as far as keeping the house cool WHITE or SILVER? thanks troy p.s. i just installed a quadrafire wood stove for heat and man is it awesome!
joesgot4 -
I vote white with an elastomeric paint/coating. CarloSW2 |
There are companies that offer special reflective pigments in their metal roofing paint to further reflect light. I'd check that out.
I would go with silver as it's going to be cheaper and zinc oxide white, if I remember right has this nifty property where it is able to reflect light and heat and also radiate heat faster then other colors, and over time that silver galvanized metal is going to turn gray from the zinc turning to an oxide.
It's also a classic and if you are going to buy a roof that will last 100 years go with a classic, either way the paint is not designed to last 100 years. |
Unless you absolutely need to redo the roof, wouldn't a radiant barrier stapled in the attic be the cheapest solution?
Most of the roof colors have the same efficiency. Check the company you are going to use to see if the roofing is energystar rated, if it is the colors will be the same and there is a tax credit.
"Englert’s Ultra-Cool metal roof coatings dramatically increase the reflectivity of medium to darker color roofs, meeting Energy Star specifications for cool roofs. Consequently, architects and builders can enhance the appearance of their projects with the use of medium and darker colors and save warm weather energy costs because reflectivity keeps the roof and interior spaces cooler. In addition, the use of Englert’s Ultra-Cool metal roof coatings has several positive impacts on the roof, its structure and the environment. Heat is reflected away from the building, urban smog is reduced when environmental temperatures are reduced, the life expectancy of the roof increases due to less expansion and contraction and public monetary incentives are available for using reflective roofing products. Englert standing seam metal roofs are available in a wide variety of Ultra-Cool colors including dark bronze, charcoal gray and matte black."
My neighbor is a dealer for Englert. This is from thier site. |
jmf -
Englert: Ultra-Cool Coatings are available in the following popular colors http://ecomodder.com/forum/member-cf...oof-colors.jpg In the above you can see that the white has a better Solar Reflectivity Index ... Atlanta Roofing | Cool Roofs | Green Roofs | LEED Certified Roofs | Solar Roofing in Atlanta | Green Wave Forever Quote:
a roof should get hot, there is organic and gases in the house that need out, and other physics that just needs up, unless you have a common sensed air circulation? making a dirty old barn out of the house ...ewww. |
