EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Why do a grill block when you could put excess air to good use? (https://ecomodder.com/forum/showthread.php/why-do-grill-block-when-you-could-put-18830.html)
ConnClark 09-15-2011 06:17 PM
Stick one of these in front of or behind your grill and you will get the same effect as a partial grill block and some energy back to boot.
BPE14 TURBO STAND-BY ALTERNATOR from Aircraft Spruce
Sounds like a good idea but would it be really?
CigaR007 09-15-2011 06:38 PM
As per the specs, it only outputs 6 amps @ 85 mph; not a great speed for hypermiling, not to mention the probable increase in drag upfront.
deathtrain 09-15-2011 06:46 PM
because its $800.
Daox 09-15-2011 07:14 PM
Mostly because you want the car to go through the air as easily as possible. If its spinning a turbine, no matter if its in a grill or strapped to the top of the car its still spinning that air blender up.
Thymeclock 09-15-2011 09:29 PM
Aerodynamics are one thing, but the reason most of us in Northern climates use a grille block is to have the engine warm up faster in sub-freezing temps.
ConnClark 09-16-2011 12:19 AM
If it is in the grill and spinning the turbine it is creating resistance to the flow through the grill, just the same as a grill block. This forces more air around the car and thus helping it cut through the air more cleanly.
Frank Lee 09-16-2011 12:36 AM
There ain't no free lunch and it takes more power to spin that thing. Grill blocks BLOCK the internal flow; this does not.
HighMPG 09-16-2011 01:21 AM
Hey, I got one of those on my plane!
ConnClark 09-16-2011 12:48 PM
A 100% grill block blocks internal flow. A partial grill block impedes it. The turbine will impede it as well. Its not a free lunch. Its taking a bite out food you have already paid for before it rots.
tortoise 09-16-2011 05:27 PM
A grill block giving the same reduction of internal flow as the turbine will reduce power required more than the turbine would have produced. Unless the turbine is greater than 100% efficient. Give up on this one.
