Old 02-02-2009, 10:07 PM   #1 (permalink)
My favorite hand air pump
Hi,
Here's an excellent hand pump that I just bought, and it makes it quite easy to pump up car tires:
Topeak® Cycling Accessories — Products - JoeBlow™ Sport
This pump is as near to perfect as I have ever seen. It has the gauge built right in, so you can see the pressure as you pump; with a bleeder valve if you go too high. It has a large metal base that is very stable, and the handle is wide enough to use both hands. The hose is fairly long and the base pivots. It has both a Schrader and a Presta valve connector, and they do not leak -- and they pop right off. It takes far less effort to use than any other hand pump I have used. It stores all the accessories on the pump, and the hose clips in so as to hold the handle in place.
What's not to like? It is not inexpensive (I paid ~$46), but it is well worth it, in my opinion.
Old 02-02-2009, 11:03 PM   #2 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
Is it a dual-action pump? Meaning that it sends pressure to whatever you're pumping on both the up and down stroke?
Old 02-03-2009, 12:17 AM   #3 (permalink)
I got one of these, much easier to use than a hand pump, works great.
Michelin Twin Barrel Foot Pump
Didnt buy it there though.
Old 02-03-2009, 06:12 AM   #4 (permalink)
Hi,
I don't know if it dual action -- I'll look at the dial the next time I use it.
Old 02-03-2009, 07:57 AM   #5 (permalink)
Custom User Title
Daily Driver - '02 Pontiac Grand Prix SE
90 day: 18.45 mpg (US)
you can feel it if it's dual action. My pump is not, the upstroke is easy, down stroke is hard. I've done the flat to not flat pump with it, and it sucks. Just doesn't move the volume of air a car tire needs. It moved up to 15psi fairly well, only took me 15 minutes of constant pumping, but getting to 25psi was another 15 minutes. Glad I had nothing better to do at the time.
In a pinch, they'll do, but don't expect to go anywhere anytime soon..
Old 02-03-2009, 08:48 AM   #6 (permalink)
Hiya,
30 minutes of pumping?! I moved from nearly flat (one of my snow tires had sat for 2 years) to 40PSI is ~3-4 minutes, with my Joe Blow!
Old 03-02-2011, 01:24 PM   #7 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Hi,
That's kind of pricey for a bicycle pump. How fast and easy is it compared to a bell pump, for example? It takes me 60 pumps to get from 15 to 22 pounds in a tire, and they get harder from there. I figure that would be 300 to 500 pumps to 40 pounds, for each tire. That's impressive that you can get to 40 pounds in 3 or 4 minutes.
Electric water pump Gregte DIY / How-to 96 05-08-2022 03:49 PM
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 3 03-11-2012 09:41 AM
Woo Vacuum Pump! trebuchet03 The Lounge 10 05-14-2010 12:52 PM
Geo Metro Fuel Pump Circuit bennelson EcoModding Central 12 10-05-2009 04:43 PM
Same Gas Station - Same Gas Pump - Better FE ??? BlackDeuceCoupe General Efficiency Discussion 14 10-22-2008 03:03 PM
