Why over the top?
Toilet paper!
You go to a rest area, or park where the rolls are stiffly mounted. You struggle ripping shreds wasting paper, and getting angry! THEY figure if you have to FIGHT for it; you'll use less!?! To me gravity, and common sense say let the tissue drop like it wants to from behind!! Why does the world have to be so crazy?? |
Uh-oh!!!! Here we go - - - the war will soon start - - - politics, religion, or - - - toilet paper orientation!!!!!!
:eek: |
Kinda hard to see why rolling would be harder in one direction than the other. Though I do think "over the top" is a little easier to get to...
Your ordinary toilet roll is essentially a large hole mounted on a thin roller.
One of the issues is that rest areas use bigger rolls on larger diameter rollers. Being bigger, the rolls are also heavier. Using a bigger diameter roller, means more rolling resistance Being heavier, they are harder to get rolling and keep rolling (Newton and rolling resistance). The end result : the force needed to overcome this inertia is close to the sheer force of the (partly) separated sheets ... |
And this is why society eventually began using the three seashelles..
If you apply for a function in an office that boasts being 'paperless' - check the restrooms before committing to - well, anything ;)
At my wives office, before they closed it down to move office to 'cow meadow', they literally tried to save on toilet paper - resulting in employees fleeing home for essentials... In our office at the printers we are advised to use double sided printing - "using both sides saves trees". In several separate locations people have penciled in suggestions about expanding this practice to the private rooms. |
To be clear, I think the orientation should fall from the front, so if it's at the top, it falls down the back and hangs at the front.
Personally, I always make sure this is so at my residence. But if I spent my days working in restrooms, with dirty toilets, dirty floors, and usually completely careless people, I would just get in there, load it up however it may be, and that'd be that. Heck, if I came in there to a mess, I may intentionally get even by doing it the opposite way lol. Funny how that's my idea of revenge...YOUR TOILET PAPER ROLL IS BACKWARDS. THAT'LL TEACH 'EM. |
Just got done reading this thread. I want my 5 minutes back.
Well; Gee! The lounge is for lighter subjects, what could be lighter than
toilet paper. Ah yes, a doo, doo, of a subject! PS. It sounds like some of you have never visited a rest area!!! |
/RIMSHOT |
